Like Tree2Likes
Old 12-10-2014, 11:15 PM   #481
CraigMBA's Avatar
Trader Rating: 22 (100%+)
The Evo6 shocks are definitely larger.
I have one of everything else but the 418 shocks. Tb04, mini, 417, black, you name it.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 12-10-2014, 11:55 PM   #482
Same as me, even have the aerated ones
As mentioned the 419 shocks have more internal volume, the plastic piston top is larger to match. Its all internal so you will still be able to use the same springs retainers etc.
Its a very nice kit, has pretty much everything you want in the box..unless you want blue screws... and we all want them
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-11-2014, 12:36 AM   #483
419 has different pistons and shaft retainer for sure.
My rear diff leaked for first 5 runs.. Will need to check next race to see if it continues. The new. Diff also uses new sized gasket which I don't have yet...
Gordie88 is offline   Reply With Quote
Old 12-11-2014, 03:24 AM   #484
Does the diff still use the stupid little self tapper screws that are supposed to be 1.5mm hex but no 1.5mm hex drive - except for the crap one included in the kit or one that is worn to buggery - fits into?
Those damn screws suck!!
cplus is offline   Reply With Quote
Old 12-11-2014, 04:39 AM   #485
Simmi's Avatar
Yesterday I was on a new carpet track with Marc's setup. I drove like soap and my diff was also leaking.
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 12-11-2014, 07:18 AM   #486
Thats not great! did you use the brown or black O ring?
Old 12-11-2014, 07:28 AM   #487
sohlman's Avatar
Trader Rating: 89 (100%+)
Wonder if the trusty orange Kyosho o-rings will work in the 419 diff. I haven't had a leaky diff on my 418 & 417 for two years.
Steve Sohl
sohlman is offline   Reply With Quote
Old 12-11-2014, 09:01 AM   #488
Trader Rating: 16 (100%+)
Anyone track tested the 419 on asphalt yet? Any feedback?
Does the 419 diff fits nicely on the 418?
ronaldo-1234 is offline   Reply With Quote
Old 12-11-2014, 11:45 AM   #489
sakaguchinet's Avatar
Send a message via ICQ to sakaguchinet Send a message via AIM to sakaguchinet Send a message via Skype™ to sakaguchinet
Hi,
here is my setup from ETS Hrotovice (CZ):
http://www.rc-square.de/downloads/20...-Hrotovice.pdf
I have to say, that the new Diff is really good. Just built like the manual says, and only 1x refilled on saturday evening. So much more durable (mechanically).
The feel of the car was good. Very similar to my 418IIX. Had no direct comparison, as I drove the 419 in Mod and the IIX in Stock.
From setup point of view no experiments were done. I've played around with different wheelbases and a bit with the ackermann steering spacer (ended up with 0.5mm). The motormount was fixed centrally (with one screw in front and rear). Basically Marc and Viktor were also driving this setup (only difference: The Alloy Lowerdeck - which was reportedly more easy to drive on that conditions).
Important: All my setups are based on the "old" 5mm ball connectors (which are, compared to the 418/419 ones 1mm down type).
Best Regards,
Dai
http://www.rc-square.de (German and English manufacturers site)
http://www.sakaguchinetshop.com (Tamiya TRF related stuff)
sakaguchinet is offline   Reply With Quote
Old 12-11-2014, 01:11 PM   #490
Dusttt's Avatar
Trader Rating: 118 (100%+)
Originally Posted by RC MARKET View Post
this week arrive $455 only !
Ordered mine earlier this week. I will update on its arrival.
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 12-11-2014, 10:02 PM   #491
Simmi's Avatar
Thank you Dai for your Setup Sheet and your Tip with one screw for the Motor Mount
As always, I have a video made by the new 419 on youtube:
https://www.youtube.com/watch?v=pfgi...XDA9wFcpeYOY_Q
Team Yokomo YZ2 CA
Old 12-11-2014, 11:46 PM   #492
Simmi, couple of queries
Why the roche cups - aren't the new ones blade free? Didn't want to try them?
Shorter turnbuckles are an oddity. I was thinking of grabbing a BD7 (Lunsford) kit to use, the equivalent are all slightly shorter than typical Tamiya as well.
What screws have you used - your button heads all have a little lip?
Old 12-12-2014, 06:28 AM   #493
Trader Rating: 77 (100%+)
Did the 419 new kit come with the body post blue mounts?
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 12-12-2014, 09:09 AM   #494
RC MARKET's Avatar
Morning will ship !
& TRF419 some spare parts arrived !
www.rcmarket.com.hk
Tamiya TRF419-ta-51564.jpg   Tamiya TRF419-ta-51568-1.jpg   Tamiya TRF419-ta-51570.jpg   Tamiya TRF419-ta-51571.jpg   Tamiya TRF419-ta-51573.jpg
RC MARKET is offline   Reply With Quote
Old 12-12-2014, 09:04 PM   #495
TB03Racer09's Avatar
Ordered my Trf419
TB03Racer09 is offline   Reply With Quote
