Like Tree9Likes
Old 10-22-2014, 10:54 PM   #361
Clawhammers's Avatar
Originally Posted by EDWARD2003 View Post
If you want cheap prices in Japan = Yahoo Japan Auction baby!
Or if you want to buy new, RC Maniax has decent prices.
How about that motor mount?
IMHO.
If you are overseas customer, Banzai, Pro-shop Futaba and RC-Champ are the only retailers who are willing to sell to you.
If you are local, then (in addition to the above 3 retailers) RC Maniax, RC-Funfun, and Rakusei Model are preferred online retailers due to their huge inventories and cheap / discounted pricing. Note that this shall also subject to your domicile / location in Japan.
Yahoo Auction in Japan also deliver services to foreigner, but you should use their official Buyee services (added with % of fees and commission).
Last but not least, I just checked with a friend in Japan, the consumption tax is still 8%.
This rate will increase to 10% on October 2015.
Sorry, I couldn't answer Edward's query concerning the motor mount.
Hope this helps
Clawhammers is offline   Reply With Quote
Old 10-23-2014, 01:46 AM   #362
quite pretty really. top notch anodizing as always!
pity it is still two piece, the BD7 has moved to one piece. I do wonder the whys/ways of one side vs two side. Tamiya obviously feel that 2 side is better for some reason, there has been plenty of examples to compare/copy.
2014
2015
cplus is offline   Reply With Quote
Old 10-23-2014, 01:46 AM   #363
oh, and here is a page to bookmark in advance!
http://www.petitrc.com/reglages/tami...iyaTRF419.html
Old 10-23-2014, 02:43 AM   #364
niznai's Avatar
2014
2015
Looks one piece to me.
Or are you wondering why they don't use a cantilever centre pulley?
I don't think there's any significant advantage of one option over the other. Maybe a cantilever setup allows changing belts easier but not that big a difference.
The only thing is the way that mount is machined, it may distort.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 10-23-2014, 02:43 AM   #365
Burlap's Avatar
Send a message via MSN to Burlap
I used to use RC Champ for years, and brought my original 415MSX from them back when it came out. However in the past year they have stopped replying to my emails, which is a shame
Burlap is offline   Reply With Quote
Old 10-23-2014, 04:23 AM   #366
The second piece isn't shown in that image.
You can see the machining/screw hole where it will attach at the front. This will attach to the top deck.
What email are you using? It changed at one point.
Old 10-23-2014, 07:18 AM   #367
niznai's Avatar
Oh, I see.
But why does this matter? It's just their way of achieving the same result. Not one iota of difference in function. The functional difference will come from the way the larger footprint Tamiya item will impact chassis flex.
Team Greasy Weasel
Old 10-23-2014, 01:31 PM   #368
Oh, I see.
It matters as there is a massive drop in function!
It's a twist point as there still needs to be clearance between the two parts and it gets even worse if the screw becomes even remote loose.
The footprint is no larger than the yokomo (it may even be slightly smaller?)
It only touches the chassis at the ends where the screw are.
Old 10-23-2014, 10:24 PM   #369
niznai's Avatar
Wrong again. My eyes are not what they used to be. You're right.
As for the screw coming loose, I think that fear is easily addressed with a dab of loctite (in fact I would loctite it forever there for fear of losing it in my spares box). If I intended to use it, that is. Most people don't seem to use that pillar on the Yokomo chassis at my track (nor do I), so I guess it's a case of figuring out what you want to do and deciding then.
Team Greasy Weasel
Old 10-24-2014, 12:35 AM   #370
Loctite would work of course - it would still move (microscopic!) and would be even better if it was just one piece.
Would be much harder to machine though!!
Old 10-26-2014, 08:07 PM   #371
niznai's Avatar
How anal do you want to get? Microscopic? I doubt you'd be able to tell unless you removed all chassis flex, all top deck clearance at screw holes, bulkhead mating lines, and on and on and on, and by the time you finished, you'd have probably built the space shuttle.
Team Greasy Weasel
Old 10-26-2014, 10:24 PM   #372
No of course you wouldn't be able to tell if it was done properly. I'd just prefer something solid rather than relying on a loctite screw.
But, if it's a flex point anyway then probably doesn't matter.
Old 10-27-2014, 07:44 AM   #373
Electr0n's Avatar
Motormount 2 parts ! Could be worse
Tamiya clone in 3 parts ?
Or ?
Easier to change spur
Andre
M-03, M-05, TB 03 (R+), TB-04 Pro (R), TT-02 S, TRF 417X, TRF 417V5, TRF 418, TRF 419, All TB EVO Chassis, TRF 414 and .....
Electr0n is offline   Reply With Quote
Old 10-27-2014, 03:48 PM   #374
No 4 (let alone 5) axis CNC mill in the Capricorn factory obviously
Old 10-27-2014, 06:43 PM   #375
Burlap's Avatar
The Yahoo one they have on their website
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
F N CUDA
