Like Tree11Likes
Old 08-03-2017, 02:08 AM   #3496
Tom1977's Avatar
I use X-rings 50dm.
Tom1977 is offline   Reply With Quote
Old 08-12-2017, 03:03 PM   #3497
nubs's Avatar
What brand spur is everyone using? What size? 48 or 64?
nubs is offline   Reply With Quote
Old 08-12-2017, 06:08 PM   #3498
Tom1977's Avatar
Robitronic spur gears (machined delrin) in combination with Arrowmax pinions. Both 64dp.
Robitronic RC Shop | Zahnräder & Ritzel | rc car, rc heli, rc planes
Gears
Old 08-12-2017, 10:08 PM   #3499
F N CUDA's Avatar
Trader Rating: 30 (100%+)
https://www.tqrcracing.com/shop/prod....asp?p_id=9312
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 08-13-2017, 04:45 AM   #3500
Stein Tumert's Avatar
Panaracer
64 on carpet and 48 outdoor.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 08-13-2017, 11:44 AM   #3501
Simmi's Avatar
Xenon only 48dp
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 08-13-2017, 12:10 PM   #3502
Panaracer 48dp
Macio4ever is offline   Reply With Quote
Old 08-13-2017, 01:59 PM   #3503
Dusttt's Avatar
Trader Rating: 123 (100%+)
Same here, except I went one step farther. I also got the reinforced black rod guides. To get even more consistent feel, I also drilled a hole in the plastic piece of the top cap.
Part number for these and the clear o-rings please.
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 08-13-2017, 03:23 PM   #3504
nubs's Avatar
54730
53574
Old 08-14-2017, 04:50 AM   #3505
maxepower's Avatar
Smile favorite spur gears!
For 64 pitch I like the Axon spur gears
For 48 pitch I like the 3Racing spur gears
I haven't tried the 48 pitch on the 419x but I think the it's thin enough to fit between the center pulleys ?
Just my 2$
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 08-14-2017, 06:35 AM   #3506
nubs's Avatar
Just my 2$
My problem with 48p is getting down to 3.2 fdr. It's been difficult to find a brand that has teeth at around 65 that also have the right fit for the pulley.
Old 08-14-2017, 09:21 AM   #3507
Robinson makes a 66t 48p spur gear and hirosaka makes a 65t spur that is very thin...
bertrandsv87 is offline   Reply With Quote
Old 08-14-2017, 09:34 AM   #3508
nubs's Avatar
Yes but the Robinson spur is too thick. Kimbrough spur gears have the wrong drill hole pattern. I ordered a 69T for the serpent cars. I assume its made by Axon.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
Old 08-14-2017, 01:23 PM   #3509
Then the hirosaka spur will be best at 3mm thickness. It might be hard to find...
