Like Tree6Likes
Old 06-19-2017, 07:03 AM   #3421
Tom1977's Avatar
Originally Posted by nubs View Post
Most others I've seen used red. But I wouldn't​ be surprised if he was using the harder set(pink or purple) as well since he thought the Tamiya springs were too soft.
I personally use purple front and red rear progressives for my 419x on asphalt. Was from the last year Marc Reinhard setup.
Tom1977 is offline   Reply With Quote
Old 06-19-2017, 07:56 AM   #3422
nubs's Avatar
Yeah I think the most important piece of information is that he was using progressive smj, drivers should use the colors that are appropriate for their track conditions.
nubs is offline   Reply With Quote
Old 06-19-2017, 08:40 AM   #3423
Stein Tumert's Avatar
Default Tamiya 51293
Originally Posted by Simmi View Post
Is the point that the 51293 has a better material than the 54031, or does the 54031 not fit the 419x?
Stein Tumert is online now   Reply With Quote
Old 06-19-2017, 08:42 AM   #3424
Originally Posted by Skiddins View Post
Anyone know what the progressive springs are that he used?
Mentions SMJ's
His setup will likely come up on Petit RC soon...
Old 06-19-2017, 09:17 AM   #3425
Tom1977's Avatar
His point is:
51293 glass fiber injected mold plastic = less brittle on impact
54031 carbon fiber reinforced plastic = more brittle on impact
Old 06-19-2017, 09:28 AM   #3426
His point is:
OK, clear. What is the application/use for the 54031 then?
Old 06-19-2017, 09:33 AM   #3427
Tom1977's Avatar
Same as 51293 but harder material. If you are not prone to crash your car at full speed regulary you can choose the harder version.
Old 06-19-2017, 12:25 PM   #3428
StickyFingaz's Avatar
Trader Rating: 12 (88%+)
Guys, what's your opinion on the 419x... still competitive? I've been out of TC for a few years now but have always loved TRF quality, even ran for Tamiya USA for a while. I'm seeing some good deals on kits floating around everywhere, but am worried with little development this car may not be competitive in a season or two, maybe even now... such is the case with TC, development is very rapid.
If you all think objectively as a pay-for-everything privateer for a moment and not as a Tamiya fan-boy like myself, would you pull the trigger on a kit that's been in existence for over a year now? Car will be run in Mod, against the likes of EJ Evans, Lex Tyler, Ethan Erchinger, Gonzalo Cortes, Eric Albano, Clements.... the usual fast NorCal suspects. It's silly... but part of my leaning towards the 419x is I still have a lot of old parts and gear from the 416/417/418s I ran in the past that I don't know what to do with.
I appreciate all of your guys' insights!
Martin M.
Team Tamiya/TRF - Team KO PROPO - NorCal Hobbies
StickyFingaz is offline   Reply With Quote
Old 06-19-2017, 12:52 PM   #3429
Tom1977's Avatar
Martin M.
I see no reason why 419x should not be competitive anymore. Most TC's are very similar buildt today. If you like Tamiya and have experience with other Tam-kits, buy it, especially the new XWS-kit. 419x has generally very good part quality. Only diff is a bit tricky to get leak free. But there is a new aluminium hop up to solve this problem.
Old 06-19-2017, 01:32 PM   #3430
B. Santos's Avatar
Martin M.
I think your assessment is right on. As you mentioned the lack of development is really starting to show. Newer developments in the TC scene like pitch control or active rear suspension are only available by fitting other manufacturers parts.
I run the 419X locally in 17.5 TC, and am usually mid-pack.
I went through the same thought exercise as you a few weeks ago and ended up purchasing an A800X for my next kit.
B. Santos is offline   Reply With Quote
Old 06-19-2017, 02:45 PM   #3431
Ivan Dickson's Avatar
Trader Rating: 9 (91%+)
The 419X works with the right setup, I just watch the ETS Hudy arena and the winner
of Stock class won A1 & A3 with 419X over a top notch field, click here to see video.
I myself have the old 419 and the new 800X, and my Awesomatix is better but
my 419 is no slouch and has beaten some 800 before, so it comes down to
skill level & setup.
Stein Tumert likes this.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 06-19-2017, 02:47 PM   #3432
nubs's Avatar
That is sad but understandable.
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
Old 06-19-2017, 09:37 PM   #3433
Martin M.
EJ's Top Saber is 3 years old. The 419x is a great car that most of us just don't have the skill set no matter what chassis were using to drive against the best around
Juan Aveytia is offline   Reply With Quote
Old 06-19-2017, 09:38 PM   #3434
I will bet you you'll hit the same fast laps with the 419x as the awesomatix
Old 06-19-2017, 09:39 PM   #3435
I think I will break out my 414 to prove it
