XRAY X12 - 2015 Specs
#121
#124
Please note.... servo saver must be processed, otherwise he looks out of the chassi
#126
thank you:-)
holder is approximately 3g, and srg-hr is 21 ... the same weight as a futaba S9650 only.
#127
Built my X12 '15 last night and as usual for XRay it was a beautiful kit to assemble. I used exactly the same components and wiring that I had in my CRC (including a graphite axle). For the CRC I needed to add 24g to come up to weight but with the XRay I ended up 15g over.
Tires are CRC and a trued to 41mm rear and 40.5mm front.
Same motor, ESC, receiver, servo (tiny little airtronics one, can't remember the model but mounted it directly to the chassis with one custom screw hole so not even using the servo mounts), servo saver and body (AMR Light Weight). The XRay is definitely a tank of a 12th scale.
Perhaps this is something that can be worked on for the next version? Who knows. Going to get a Hiro Seiko screw kit for it but can't see that shaving off 15g considering the little number of screws on the car.
Luke
Luke
#128
Luke
Luke
#134
Do you have the graphite axially use?
what needs to weigh it for racing? 730g?
