Old 11-02-2014, 05:51 AM   #91
Originally Posted by CraigX View Post
IIC 12th Scale Stock winning setup for X12'2015
Feel free to ask any questions here.
hello man whall wiil be the gear ratio for an 8,5 and 6,5 motor, thanks
chachotu is offline   Reply With Quote
Old 11-03-2014, 03:40 AM   #92
Hi,
what is needed to fit Associated side springs?
Claude
toroloco is offline   Reply With Quote
Old 11-13-2014, 03:53 AM   #93
Migigu's Avatar
you need xray 373590
Migigu is offline   Reply With Quote
Old 11-13-2014, 03:57 AM   #94
Peakki's Avatar
Originally Posted by toroloco View Post
Hi,
Claude
I would use instead of those AE aluminium side spring retainers. R5.2 part, don't remember part number. The xray spring retainers don't work so well with other make springs, because of different spring diameter...
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 - Team Orion R10.1 Pro & Sanwa Super Vortex Zero - Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa servos
Peakki is offline   Reply With Quote
Old 11-13-2014, 06:54 AM   #95
HI,
Thanks o Migigu and Peakki
@ Peakki so the old retainer's from AE 4640 will also work?
@ Migigu is it correct that you are running an LRP WT Flow without a Booster or Lipopack?
Claude
Old 11-13-2014, 08:45 AM   #96
Migigu's Avatar
is correct :-)
Old 11-13-2014, 09:00 AM   #97
Originally Posted by Migigu View Post
is correct :-)
So I will try it too, hope it works with my Sävox Servo
Thank's
Claude
Old 11-13-2014, 01:39 PM   #98
Migigu's Avatar
I think the Savöx servo can do it, the question is whether your receiver can it? My receiver is a Sanwa RX-451R, which can be 1 cell use. Transponder? My Old MYLAPS transponder AMBrc it could not, I then moved on MRT, the can 1 Cell. The new MYLAPS transponder can be 1 cell use.
Old 11-13-2014, 07:55 PM   #99
AL1983's Avatar
Hi,
Question: If I reverse my antenna plate (point facing forward) and buy 378071-O adapter will I be able to perform the long shock mod in my 2014 X12?
Thx for replying!
Yokomo BD7'14, Muchmore Fleta Euro, Muchmore Fleta ZX, Thunder Power!!!
AL1983 is offline   Reply With Quote
Old 11-14-2014, 01:25 AM   #100
Migigu's Avatar
yes you can use. x12 14 in the damper must longer than in 2015, but it should be enough.
Old 11-14-2014, 01:27 AM   #101
Hi Migigu,
I have a Sanwa RX471 receiver and an MyLaps RC4 Hybrid Transponder.
Do You have a part number or a link where I can buy a PTX just in case?
Claude
Old 11-14-2014, 02:07 AM   #102
Migigu's Avatar
I do not know if the rx-471 goes. by lrp page is 4.8-7.4 voltage. I'm not sure but somebodies here in forum wrote it also comes with rx471. your transponder should go.
Old 11-14-2014, 02:23 AM   #103
Skiddins's Avatar
Run an RC Dynamics booster and thats your voltage problems solved.
http://www.rcdynamics.co.uk/Products.html
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 11-14-2014, 03:30 AM   #104
Sorry but no,
If I look at the price for the booster + ESC I can have an Orca 1s with the prog. Card and I don't have to solder and cut cables an I keep the LRP for my TC.
Claude
Old 11-14-2014, 05:01 AM   #105
Hobbyking also have a 1S voltage booster and I've had more success with that one than I had with the RC Dynamics booster.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
SEO by vBSEO 3.5.0
