Old 01-20-2015, 02:21 PM   #226
haywood's Avatar
Trader Rating: 48 (100%+)
Default X12 2015
Pretty quiet on this thread. I'm still having good luck with this kit myself!
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-20-2015, 04:29 PM   #227
Trader Rating: 29 (100%+)
Me too. I'm very happy with mine. After replacing some of the front end with Associated/ TOP stuff, as others have discussed, I have zero complaints. I ended up drilling some new holes and installed a KO rsx12 servo also.
branover is offline   Reply With Quote
Old 01-20-2015, 05:20 PM   #228
Regional Moderator
disaster999's Avatar
Same here, Im satisfied with the car and its providing enough fun for me. Im sticking with the front end just because I didnt want to deal with sourcing parts for it (1/12th is not extremely popular in Hong Kong and I dont want to pay for international shipping which may or may not cost the same as the parts itself)
Anyone know if the VBC front end would work? Im sure I can get parts for that easily as a local shop is the distributor for them.
Im running around a 77mm rollout and 30% turbo and Im still begging for more speed at my local track. Time to jack up the turbo even more.
disaster999 is offline   Reply With Quote
Old 01-20-2015, 05:39 PM   #229
Regional Moderator
Originally Posted by haywood View Post
You will need the following parts from the 12r5.2...
Upper eyelets
Kingpins
Shims
E-clips
Steering Blocks
Axles
2.5mm screws
Pivot Balls
We have also tried Vbc parts and Xenon parts as well.
Seems like my question was answered in the previous page...Haywood, does the VBC front end work just ask good as AE or TOP or Xenon parts?
I noticed you didnt mention the bulkheads, will the stock xray one work?
Old 01-21-2015, 12:22 PM   #230
Does anyone know which US distributors have graphite axles in stock?
xen0ph0n is offline   Reply With Quote
Old 01-21-2015, 01:29 PM   #231
haywood's Avatar
http://www.amain.com/xray-graphite-r...0#tab-feedback
Old 01-21-2015, 02:27 PM   #232
Oh, cool. They were out of stock when I checked a few days ago.
Old 01-29-2015, 09:58 PM   #233
I got a new x12 15 ordered and I plan on running 13.5........ What size spurs/opinions do I need to get for it?
Track Owner "The Compound R/C MX" at the Miller Brothers Racing Compound.
Vehicles: Losi 22 SCT, Losi SCTE with MIP, Losi SCTE 2.0, Kyosho STrr Evo, Kyosho Mp9 TKi3 x4, Tekno SCT 410, Blade 350QX.
MBRcompound is offline   Reply With Quote
Old 01-29-2015, 11:17 PM   #234
Regional Moderator
I would definitely go for the smaller 78 or 76T spur gear.
I was recommended a 70mm rollout for a 10.5T and Ive seem people run a 95mm rollout for 17.5T. In order to get these crazy rollouts you need a small spur and large pinion and you cant do that with the stock 98T spur.
Im running a 78/40 on my car right now and still feels slow on my local track. I had to turn up the turbo to around 50% in order to hang with other people
Old 01-29-2015, 11:51 PM   #235
I'd like to put 3-5mm spacers under the center shock mount on the rear pod. The standard 4.2mm ball-end that comes with the kit isn't long enough for anything bigger than a 2mm spacer. I'm having trouble finding a 4.2mm ball-end long enough.
For anyone who's added spacers here: how did you do it?
Brian Mann
ARC R10 2015 Black Edition
Old 01-30-2015, 12:33 AM   #236
Regional Moderator
i think your best bet is to find a female ball end of the same diameter and a screw long enough.
Old 01-30-2015, 01:41 AM   #237
Skiddins's Avatar
Replace the rod end with the slightly larger version from an Xray touring car (4.9mm), now you can fit any of their ball-end's which come in 5, 6, 8 and 10mm.
Thats what Olly Jefferies did and I copied his.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-30-2015, 04:08 AM   #238
I'd say get some spurs ranging from 70t-80t and pinions from 48t-56t
I've had good success with a 72 spur, 54 pinion, 41mm tires. Gives me a 96.6 rollout.
Old 01-30-2015, 05:47 AM   #239
Skiddins's Avatar
The white is PTFE tape to reduce any slop
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-30-2015, 01:09 PM   #240
That's what I was planning on doing. I'll go ahead with it then. Thanks!
EDIT: The white PTFE tape is a really good idea. Hadn't thought about doing something like that.
Brian Mann
