Old 12-23-2014, 12:33 PM   #211
Originally Posted by Maxime View Post
Thank you for the infos about the servos. I installed a Futaba S9650.
Another question: Where can I buy spare parts for X-Ray cars, besides A-Main where everything I need is backordered...?
The-Border.com, realtime XRAY stock: if you can purchase it on the website, it's in stock.
Thaan is offline   Reply With Quote
Old 12-23-2014, 01:43 PM   #212
Everything you ever need to know about servos - all of them!
http://www.servodatabase.com/servo/futaba/s9650
SlowerOne is offline   Reply With Quote
Old 12-23-2014, 04:05 PM   #213
Well not quite everything...that is the best resource available though. What no one seems to list is the distance from the center of the output shaft to the center of the servo mount holes. I've had a few times where a servo will fit dimensionally but the servo saver isn't centered in the chassis. I really wish they would list that in the dimensions.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 12-28-2014, 02:44 AM   #214
Hi
What are the little tricks that people have found during the build process?
BD7 2014 mod, BD7 13.5, Serpent S120 ltx 10.5
marcvanderzon is offline   Reply With Quote
Old 12-28-2014, 06:56 PM   #215
haywood's Avatar
Trader Rating: 48 (100%+)
Default 2015
Originally Posted by marcvanderzon View Post
Hi
Car build is straight forward and parts are good quality. In order to get the car down near min weight you will need the graphite axle and titanium screw kit. You can buy the Xray axle or convert to the Irs style axle that is even lighter. The front end tends to be a little loose or sloppy so you can convert to the Associated front end parts to fix that problem.
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-28-2014, 07:13 PM   #216
Could you elaborate about that conversion with Associated parts?
Maxime is offline   Reply With Quote
Old 12-28-2014, 08:06 PM   #217
haywood's Avatar
Default 2015
You will need the following parts from the 12r5.2...
Upper eyelets
Kingpins
Shims
E-clips
Steering Blocks
Axles
2.5mm screws
Pivot Balls
We have also tried Vbc parts and Xenon parts as well.
Old 01-01-2015, 06:25 PM   #218
Regional Moderator
disaster999's Avatar
Ive been noticing this for a while but didnt pay much attention, so seeing your post and comparing it to my older 12L3/L4 12th I do notice I dont get nearly as much slop/play in the front suspension.
This is pretty disappointing.
I wonder if this is contributing to my excessive front tire wear...
disaster999 is offline   Reply With Quote
Old 01-02-2015, 06:20 PM   #219
Trader Rating: 29 (100%+)
I was pretty disappointed in the front end slop also. The car was still solid but I just replaced the front end parts a couple weeks ago with AE parts and it really made a huge difference.
branover is offline   Reply With Quote
Old 01-04-2015, 05:32 AM   #220
Regional Moderator
Did you notice any significant improvement in handling swapping to the AE front end?
Old 01-04-2015, 12:44 PM   #221
Can't say that I noticed any real difference in handling. The slop in the Xray front end annoyed me more than anything and swapping out $25 worth of parts really just gave me piece of mind.
Old 01-04-2015, 04:20 PM   #222
I'm a bit puzzled as i just built mine and front end is pretty good, with minimal slop. Is it something that develops over time or was I just lucky and got a tight front end?
rhodopsine is offline   Reply With Quote
Old 01-04-2015, 06:35 PM   #223
Regional Moderator
Once you've broken in the car you will notice the slop developing. I had the same feeling at first when I first built my car. Thinking everything seems pretty tight. Then 6 packs of battery later I noticed the slop.
For $25 its a good piece of mind.
On another note, is it normal for the chassis to twist that much the side of the chassis scrapes the ground? Its especially noticeable for asphalt when you see the chassis being worn down at the corners. My ride height is around 4.5mm
Old 01-04-2015, 07:24 PM   #224
wingracer's Avatar
Trader Rating: 22 (100%+)
Yes.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-11-2015, 05:38 AM   #225
jason cheng's Avatar
Trader Rating: 38 (100%+)
Hard hit broke the graphite axle
Xray X12 2017 x 3 / Ulti / Orca / Motiv / Team EAM / Futaba 4px / Stormer Hobbies/ Gravity Rc/ Dri-Fit Mafia/ menardsracing.com / Usinternet.com / Rc Painting By Mikey
jason cheng is offline   Reply With Quote
