Old 12-03-2014, 07:34 PM   #196
haywood's Avatar
Trader Rating: 48 (100%+)
Originally Posted by xray2050 View Post
Kimbrough Products make spur gears that fit with stock diff balls. I run the 76 tooth (#199) in 17.5T class.
We have been ordering RW spurs. Very good gears!
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-04-2014, 06:21 AM   #197
Regional Moderator
disaster999's Avatar
I went to the distributor to pick up the missing pieces today and while I was there I thought Ill pick up some spare parts as well as the xray Spur gear and pinions. Kinda ballered out on the parts, but, hey, why not.
I think Im pretty much set with these
disaster999 is offline   Reply With Quote
Old 12-04-2014, 09:27 AM   #198
Trader Rating: 71 (100%+)
If any of you are looking for a X12 2015 let me know. I have one that is brand new sealed in box. $260 shipped in the USA..
RBLove is offline   Reply With Quote
Old 12-14-2014, 08:27 AM   #199
I am new to the 1/12 world, and I got a used but mint X12 2014. I would like to know what are the parts that are Worth upgrading with the 2015 version.
I have a 76t spur and running 17.5t blinky. Tire diameter is about 42.5-43mm. What pinion should I use initially? As I read before, it seems that the biggest one I can fit is a 52t.
Thank you!
Maxime is offline   Reply With Quote
Old 12-14-2014, 08:44 AM   #200
LonnyJ1950's Avatar
You can start with the 52, but you're going to need a smaller spur. 52/76 is under geared for most situations.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-14-2014, 09:10 AM   #201
haywood's Avatar
Thank you!
We are running 70-72 tooth spurs in stock. We are very happy with the Rw brand spurs!
Old 12-15-2014, 06:10 PM   #202
Thank you for the infos.
Which servos are drop-in fit in the X12?
Old 12-15-2014, 08:01 PM   #203
Car Breaker's Avatar
As far as I know
KO pds-949 (discontinued), pds-951 (discontinued)
Futaba S9650,S9670,BLS-651
I have BLS-671svi on my X12 2-15, I had a custom chassis that have slider hole for the narrower servo. if you are using stock chassis, you can fasten the servo using far side from the spline and tape the servo to chassis. check up my earlier post for better understanding
XRAY X12 - 2015 Specs
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 12-16-2014, 06:46 AM   #204
jason cheng's Avatar
Trader Rating: 38 (100%+)
The 2 ko 949 and 951 both [discontinued] i have brand new gears, and case for the ko for sale will bolt in the stock holes 36mm wide and the futabas list below
http://www.servodatabase.com/servo/ko-propo/pds-949-ics [discontinued]
http://www.servodatabase.com/servo/ko-propo/pds-951-ics [discontinued]
http://www.servodatabase.com/servo/futaba/bls651 [discontinued]
http://www.servodatabase.com/servo/futaba/s9650
http://www.servodatabase.com/servo/futaba/s9670sv
http://www.redrc.net/2013/05/core-rc-5008-112th-servo/
XRAY X12 - 2015 Specs-ko-propo-pds-949-ics.jpg   XRAY X12 - 2015 Specs-ko-propo-pds-951-ics.jpg   XRAY X12 - 2015 Specs-futaba-bls651.jpg   XRAY X12 - 2015 Specs-futaba-s9650.jpg   XRAY X12 - 2015 Specs-futaba-s9670sv.jpg
jason cheng is offline   Reply With Quote
Old 12-20-2014, 03:15 AM   #205
Originally Posted by corally View Post
Hello
plse send a private message for servo holder, specify the number of piece want
single part price is 20/25 euro, i wait the anodization price.
Shippimg price to be define with courrirer
Friday close the list, because start production for have parts ready next week..
will you make more??? i want one , cheers
chachotu is offline   Reply With Quote
Old 12-21-2014, 05:41 AM   #206
Default servo for x12
hello i was seeing the problems with the servo, if the holes distance is 45 mm, could this servos work??
SANWA Airtronics SX-131Low Profile Servo 0.08sec 40 6V RC Car
Dimensions: 40.5x21x26.5mm
or
Hitec HS-77BB Low Profile Servo
Size in Millimeters: 43.94 x 22.86 x 24.89
i thinks the sanwa could have better fit than the hitec that could be too big??
thanks in advance
i bought an hd power servo that has a lenght of 36 mm this will work???
Old 12-22-2014, 04:28 PM   #207
Thank you for the infos about the servos. I installed a Futaba S9650.
Another question: Where can I buy spare parts for X-Ray cars, besides A-Main where everything I need is backordered...?
Old 12-22-2014, 06:54 PM   #208
haywood's Avatar
Stormer Hobbies
Discount Rc
Apex Rc
Tq Racing
Old 12-23-2014, 09:19 AM   #209
hello can you tell me what is the lenght of the base of the futaba s 9650 servo ??? because i see some webs that say 36.5 mm and another says 43mm
thanks in advance, i have bought one hd rc servo and i want to know if it will work or go to buy another one..
Old 12-23-2014, 11:27 AM   #210
pcar951's Avatar
Trader Rating: 19 (100%+)
Not sure what you mean by "base" but. The width of the 9650 body is about 36.8mm, the distance from mounting screw center to center is about 43mm. Seems to correlate with the measurements you have.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
