Old 11-21-2014, 08:06 AM   #166
Car Breaker's Avatar
Schumacher ball studs are 4.2, they have titanium one available
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 11-21-2014, 08:42 AM   #167
corally's Avatar
Hi
Schumacher ball is 4.3mm ...
CR280 - Ti Pro Ball Studs - Short - pr
Pro Ball Stud Short - pk4
Super light Titanium, 4.3mm diameter ball stud with 4.5mm length thread. 2mm hex head.
corally is offline   Reply With Quote
Old 11-21-2014, 08:52 AM   #168
Skiddins's Avatar
Originally Posted by jason cheng View Post
Please list the company that make Ballstuds in Titanium or aluminum
I'd be carful using alu ball studs. I had them for the shock on my CRC and ended up crashing out of several races after they snapped sending my into the barriers at the end of the straight at near full speed.
Xray T4'16, T4'14 (Wet Car)
Xray X12 2016
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 11-21-2014, 04:37 PM   #169
Default Gearing range problem
The track I run on likes about 95mm of rollout for 17.5 blinky. I'm just building my X12, and I'm having trouble getting a large enough pinion to fit. I have a 76 tooth spur (it seems hard to find smaller ones) and the largest pinion that will fit is a 52 tooth, which gives around 90mm with 41-42mm rear tires.
Should I just run larger tires, or try to find a 74 tooth spur? Any solutions?
xen0ph0n is offline   Reply With Quote
Old 11-21-2014, 04:48 PM   #170
http://www.amain.com/calandra-racing...ar-72t/p202698
HawaiiBob is offline   Reply With Quote
Old 11-22-2014, 06:15 AM   #171
jason cheng's Avatar
Trader Rating: 38 (100%+)
spur gears with the 3/32 balls will not work with the stock axel only gears with 1/8 inch balls will work with the stock axle or graphite X-ray axel
jason cheng is offline   Reply With Quote
Old 11-24-2014, 06:33 PM   #172
So, do you know of any spurs smaller than 74 teeth with 1/8 inch balls? Or should I just switch to mod? Or bug my club to run 13.5?
Old 11-24-2014, 09:30 PM   #173
Xenon direct drive spur gears go down to 75T...only 1 tooth larger so it should be close enough.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 11-24-2014, 10:43 PM   #174
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Love the Xenon gears. They do 16 1/8 balls in that size I believe.
Old 11-25-2014, 10:47 AM   #175
Yes they do...I have a 75T Xenon gear in mine right now Usually I use 78T but needed the extra room of the 75T for IIC.
Apex RC
Win free stuff!
Old 11-25-2014, 11:50 AM   #176
Team EAM
EAMotorsports's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to EAMotorsports
I have Leespeed gears down to a 74T in stock. Thats as small as they plan on making though.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 11-25-2014, 08:10 PM   #177
Regional Moderator
disaster999's Avatar
What are the different battery mounting options for? I see it can be mounted horizontally, or left or right vertically (inline).
Im guessing its for horizontally is more for onroad tracks and the left or right inline mounting options is geared for oval (or left or right turn bias?)
disaster999 is offline   Reply With Quote
Old 11-27-2014, 05:00 PM   #178
Regional Moderator
How rare is it for Xray to have missing parts in their packaging? I just got the kit in the mail and Im missing the caster spacers and reactive caster position holes.
I emailed Xray about it and just waiting for their reply, but want to see if anyone experienced anything like this from Xray.
Pretty bummed out to receive the kit just to find out I have to wait longer before I can go racing.
Old 11-30-2014, 02:54 AM   #179
Migigu's Avatar
a Cross... More Off Power Steering, less On Power Steering
Inline is not think fohr overal, it to weight distribution setup... Less Off Power Steering, More On Power Steering.
Is roughly
Migigu is offline   Reply With Quote
Old 11-30-2014, 06:02 AM   #180
The biggest problem of inline is lack of space . They narrow the car too much that most esc wont fit in inline configuration.
SEO by vBSEO 3.5.0
