XRAY X12 - 2015 Specs
#151
Anyone try the new graphite/ composite front end parts yet? I just put mine on today but haven't had a chance to run it yet.
#152
I really don't remember so well that have I used old AE retainers.
#153
Built my X12 '15 last night and as usual for XRay it was a beautiful kit to assemble. I used exactly the same components and wiring that I had in my CRC (including a graphite axle). For the CRC I needed to add 24g to come up to weight but with the XRay I ended up 15g over.
Tires are CRC and a trued to 41mm rear and 40.5mm front.
Same motor, ESC, receiver, servo (tiny little airtronics one, can't remember the model but mounted it directly to the chassis with one custom screw hole so not even using the servo mounts), servo saver and body (AMR Light Weight). The XRay is definitely a tank of a 12th scale.
Perhaps this is something that can be worked on for the next version? Who knows. Going to get a Hiro Seiko screw kit for it but can't see that shaving off 15g considering the little number of screws on the car.
Luke
Luke
CRC antenna mount is really light. Xray antenna mount&cf plate&alu stands weight >5g if I remember correctly.
Rear end is really solid in Xray, I think that the alu parts are heavier&stronger vs. CRC ones. Shock maybe weights more also?
Xray has big steel balls in side links also...
So xray is a bit of a tank...
#154
Hello
plse send a private message for servo holder, specify the number of piece want
single part price is 20/25 euro, i wait the anodization price.
Shippimg price to be define with courrirer
Friday close the list, because start production for have parts ready next week..
#155
good succeed! am looking forward to results! is very cheap. then please show pictures:-) Corally you come from northern italy?
#156
Hi Migigu..is your success...i only a friends with a CNC mil on garage...:=)
i live in Turin north Italy..
#157
Are you going Faloppio drive?
I would have liked to make parts, have in the next time not time. great job! make the parts anodize?
#158
No
i live on Turin so far to Faloppio....yes if possible an th price is no high..
#161
Is really hard to find Ø4.2mm ball studs. I now use in steering knuckle, asso ball cups, and titanium ball studs of a different brand that I do not remember.
I hope someone knows more
#162
Regional Moderator
Ive been out of the RC scene for 8 years and its not until recently after a trip to a local track with my ex-colleagues that I decided to try and get back in it. I decided to splurge and get myself a 2015 spec X12, Turnigy batteries, esc and motor (did some research before I purchased, Im not looking for racing, but something to bash around at the track and 1/3 the price of others is too good to pass up)
Lipo batteries and brushless wasnt a thing when I still played with RC 8 years ago and Im getting confused. The battery part I think I understand, but the whole motor rating is a bit confusing. Copying one other guy here a few pages back I bought a 10.5T motor, but still confused as to how to gear the car. Anyone have any pointers or updated links on the rollout calculation as respect to brushless motors?
Hopefully I will get my car soon and start building.
#164
