Old 09-04-2005, 05:38 PM   #1
T1Raycer's Avatar
Default Motor Break-in
i dont have the high tech stuff out there!! but can i do a break-in whit a 4 cell pack?? 3300s?? or they have other easy break in method????
also can i put a 2 run used brushes on a new freash comm or i really have to put some new brushes??
T1Raycer is offline   Reply With Quote
Old 09-04-2005, 06:18 PM   #2
i break motors in at 1.5-3 volts,
you should not have a problem using those brushes, but if you know someone with a serrator.. serrate them... if you don't... use a pencil eraser to get them as clean as you can...
if you have a auto store near you, look for a 3m rust spor remover, these ARE the fibreglass cleaning sticks trinity no longer sells. they work great for cleaning a brush so it slids in the hoods, and it's contact surface as well.
MManson is offline   Reply With Quote
Old 09-04-2005, 08:38 PM   #3
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
personally i use a 3-cell pack to break in a new set of brushes. that comes out to 3.6volts. run them in for about 5 mins or until fully seated.
and yes you can still use those brushes that have two runs in them. just be sure to de-glaze them with a comm stick or similar (as suggested by MManson). I re-use my brushes as long as they aren't burnt or less than 3/4 their original length. No need to re-seat used brushes.
ROBORAT is offline   Reply With Quote
Old 09-04-2005, 10:37 PM   #4
DIMO's Avatar
Default did
3 cells is enough to run in any brush/motor combo.
However u cant go above 2.5volts when running in XXX brushes..meaning 2cells.
BTW. Com Polish sticks arent so great the actually scratch the com..Just ask some one at your track to re-serrate your brushes. Lube your bushings and ure good to go...
DIMO is offline   Reply With Quote
motor lathe/motor break in andy_b22 Electric On-Road 4 05-17-2006 05:29 PM
Do I need to break in my new motor? Captjono Electric On-Road 6 03-03-2005 05:25 AM
Motor Break DOES Higher AMP draw = better motor? Travis S Electric On-Road 13 02-12-2005 02:02 AM
New Motor Break-in!!! hicheef Nitro On-Road 10 05-05-2003 10:43 PM
SEO by vBSEO 3.5.0
