Touring Car Tires for Asphalt.
#62
I have cleaned tires with Goo Gone. It does take off the crud, but I wonder whether the oils in the tires is being compromised.
My tracks use Team Powers 36r. They work well, but the rims are a bit fragile.
#63
I've always used wurth brake cleaner as that's what my lhs sold.
Some say to not use brake cleaner. All I know is with my tyres they're always sticky after having a good clean with it (4 race days)
#65
In Japan most of the guys who race on asphalt use
For high traction setup.
Inserts - Yokomo ZR-039M or Kawada TUB31M BAKUSO
Wheels - Panaracer Type B or Yokomo TW-2512-2 dish wheels (super cheap)
Tires - Sorex 36 or 40 (lower grip use 30 or 32)
Additive - Mighty Gripper Yellow
Tire warmers
Tire warmers
#66
Let's revive this old thread!
2020... anyone has experience with Matrix Rubber Tires mainly 36 shore (EPA-036)?
#67
Got back into parking lot onroad today after a long time off. Very low grip track with minimal spray and 70F temp. Cloud cover kept the asphalt from getting hot. I was going back and forth between sorex 32 and solaris 36. Both were pretty good on my 17.5 TC. I think Sorex 28 would have done even better.
#68
Hi,
Any opinions in the new asphalt tires from Volante (V8??), Sweep (New EPX) or Rush ??, how they compare with the classic Sorex??. There seems to be a shortage of rubber in the industry; does anyone knows the status of rubber procurement?
#69
Rush are grippy sweep ok, honestly the V8 Volante have super good grip but they are worn through after 2 or 3 races, bad
#73
At my local track and many of the tracks in the area, most people Team Powers tires (Central and Northern CA). The grip is comparable, but they last forever. My buddy and I went a full race weekend on 1 set up 34SU each (albeit on a cold day but it was over 10 runs on 1 set of tires). The Volante V8s are super (most) grippy, but only last like 1 or 2 runs. After writing this I see Lesdi said the same thing about the Volantes.
In terms of grip
Volante>Team Powers>Solaris (I haven't tried sweep or rush yet. I heard from someone that the rush were ok, but not great)
In terms of longevity
Team powers>solaris>volante
Here is some random facebook post from europe I saw comparing the team powers 36 and volante 36 in terms of wear (it doesn't list lap times so I'm not sure about that)
In terms of grip
#74
Volante V7 were good, the V8 are rubbish by comparison and I've worn through to the insert after 2-3 runs. Volante are bringing back the V7 soon, now that a key ingredient is available again (thanks COVID). The Sweep tyres are good but I have to reglue them each run as the sidewall rips easily. I tried getting 2 runs between regluing, and the sidewall ripped off entirely, throwing the insert out of the wheel. This was on low-medium grip asphalt, I can only imagine what a high grip track would do to them. I haven't tried the current batch of Rush, but their tyres were the go-to option a couple of years ago. The Volante V7 supplanted them.
#75
Let´s see what the future brings but hopefully something longer lasting than the V8...
