Deans Fake compared to fake?? and or they better?
#31
I've only plugged in backwards probably 2-3 times, and every time it was due to trying to use batteries that had the opposite plug orientation to what I was used to, and I was distracted just at the moment I was plugging in the batteries. I've also loaned a battery to someone else and watched as they immediately plugged the wires in backwards.
-Mike
-Mike
#34
The "one wire short, one wire long" method works very well until you come across a battery pack that has the polarity reversed from what you are accustomed to. Then you either plug them in backwards or if you are lucky, find out you have to rewire your speed control. I suppose you could just always stick the the same brand of battery, but over time that is unlikely.
I've used a set of "fake" Deans XT connectors that actually work fairly well. Don't know how their efficiency stands up next to the real thing, but connectors are made of Nylon which is less prone to melting if you get the metal part too hot while soldering. They also have ribs that make them easier to grab. Only problem I've run into is the extra metal clip designed to keep tension on the blades broke off after it wore from use and got caught on the plastic while trying to plug it in.
EDIT: here's a link to the ones I've used. I didn't get them from HK, but this looks exactly like them.
http://www.hobbyking.com/hobbyking/s...irs_20pc_.html
#35
#36
#37
Recently I've been using fake Deans off Ebay, and they work just fine. The springs of the plugs are tight, the plastic is sturdy, they are easy to solder...
The ones I'm referring to are a wine-ish color, pretty ugly (but dyeable, probably). I've used Orion's "fluoro" Deans in the past and the Ebay ones are just as good from what I can tell.
What I don't know is if they add resistance, but TBH I'm more worried about the resistance I might add with my lame solder joints, hehe. That said I'd be curious to know about this resistance thing. Could anyone with the knowledge and tooling compare fake Deans vs. real Deans ?
#38
Never and all of my cars use bullet connectors. You just have to glance at it for half a second before plugging it in. I don't understand how so many people make this mistake. It takes no effort to get it right and you know if you do it wrong, you'll most likely have to replace your ESC and your race day will probably be over, so why would you not pay attention while doing this? It's not hard. You just have to open your eyes.
