Old 09-03-2005, 09:32 AM   #1
Send a message via AIM to adr3naline fix
Default Positive and negative motor soldering?
Does it matter which side you solder the positive or negative wires onto the motor?
If it does matter, how and I supposed to know where which one goes?
adr3naline fix is offline   Reply With Quote
Old 09-03-2005, 09:42 AM   #2
Joel Lagace's Avatar
black(sometimes blue) wire from negative-motor on esc goes to the negative side of the motor. The endbell will normally have a - sign stamped in it.
Red wire from positive-motor/batt on the esc goes to the positive side of the motor. The end bell will normally have a + sign stamped in it.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 09-03-2005, 11:49 AM   #3
also, if you reverse the wires, the motor turns backwards.
Itchy is offline   Reply With Quote
Old 09-03-2005, 01:06 PM   #4
I know what the colors and everything are im just confused on which sides to put them on because there are no markings as to positive or negative sides.
Old 09-03-2005, 01:38 PM   #5
Secret_weapon's Avatar
I think its fine, just solder them and test it. If it was going reverse just go to the transmitter menu and make the the throttle channel inverted.
Secret_weapon is offline   Reply With Quote
Old 09-03-2005, 01:50 PM   #6
pyrosian's Avatar
What kind of motor are we talking about here?? running a 540 silver can in reverse for example won't do much but reversing a 27 turn stock motor will. Since a stock motor is set at 24* locked timing if you run it backawards it will have 24* retarded timing, meaning it will run real slow and get real hot. If you can't tell the polarity of the motor then wire it up and try it, if it's the wrong way then re-wire it the other way.
pyrosian is offline   Reply With Quote
Old 09-03-2005, 02:57 PM   #7
Myker*'s Avatar
Send a message via AIM to Myker*
word do not just change it on the transmitter. go ahead and re-solder it.
Tamiya Racing Factory
Myker* is offline   Reply With Quote
Old 09-03-2005, 05:33 PM   #8
ok ill just tape the wires on and test
Old 09-03-2005, 10:11 PM   #9
DIMO's Avatar
Default Tape
Tape LOL...the stuff that holds almost anything together
An alternative would be zipties
DIMO is offline   Reply With Quote
Old 09-03-2005, 10:16 PM   #10
i just held the wires down with my hand and pulled the trigger.
Got em on the right sides and now the thing is faster than my 11 turn mod motor. (its a EA tuned 27t Monster)
Old 09-04-2005, 12:21 AM   #11
pyrosian's Avatar
If you look closly on a monster stock there is a positive marking on the endbell of the motor. On the circuit board on the end it should say epic on one side and have a '+' sign on the other, that is your positive (red) side.
Old 09-04-2005, 07:06 AM   #12
Paladin's Avatar
just a quick note,
with the 540 motors the positive side, has a square hole punched on side of can.
Paladin is offline   Reply With Quote
soldering reedy neo-one motor help? streetracer745 Electric On-Road 11 01-06-2007 07:58 PM
need help on soldering a motor please volumefader Rookie Zone 4 06-04-2006 03:01 AM
Does my novak GTB Power capacitor have a positive and negative>????!!! Got Xray? Electric On-Road 1 05-16-2006 08:21 AM
positive negative feedback 17driver Buyer/Seller dispute and Feedback discussion forum 0 02-06-2004 09:39 AM
When to use Positive and Negative foam inserts? Remedy Electric Off-Road 0 01-04-2004 08:51 AM
