Old 01-04-2015, 12:34 AM   #706
I believe Associated calls em axle crush tubes
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 01-04-2015, 12:38 AM   #707
Originally Posted by inpuressa View Post
I think this is what you are looking for...
http://www.tqrcracing.com/shop/produ....asp?p_id=2986
thanks for the link. ill pick up a set on payday.
dragonracing is offline   Reply With Quote
Old 01-04-2015, 11:13 AM   #708
Originally Posted by nene_805 View Post
Has anyone tried the blitz tsx body on carpet? If so how did you like it. I like steering and was thinking about getting one.
It's very good on high speed outdoor tracks.
I have run it on carpet and it does have a lot of steering, A LOT.
If you're looking for something with more steering than a Speed6, then go for the GSF on carpet, it's a smaller step (and my current choice).
cyclonetog is offline   Reply With Quote
Old 01-04-2015, 12:19 PM   #709
steering rack keep coming apart. the bearings keep slipping out of the rack. happened twice yesterday. once in the mains and once testing on an oval. anybody else having this problem? i have a washer on one side but im thinking i need to add a washer on the other side too. I should not be having to do this on this car. I know its been a problem. Do you think arc has a fix for it? Has it been addressed?
Old 01-04-2015, 12:36 PM   #710
trigger's Avatar
There hasn't been much chatter about steering rack issues but the few i've heard, occurred to black edition cars. Possibly the tolerances are off because anodizing adds a minute amount of material, so ARC may have had a bit too much aluminum removed to account for the anodizing. I've gone through a few arc cars now and they have all been silver cars and zero rack issues. Worse case, install a silver rack.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 01-04-2015, 02:59 PM   #711
Mines a black edition. I may do what carnage had done is to have the rack lightly machined and install flanged bearings. but i should not have to do this. ya think? kinda sucks it came apart twice yesterday. gonna have to find a "fix" for this.
Old 01-04-2015, 03:59 PM   #712
EDWARD2003's Avatar
TKO Racing anti-slip tape!
http://tkocompetitiondev.com/index.php?cPath=151_145
Product review of the anti-slip tape.
https://www.youtube.com/watch?v=A20w8VpUW4I
TKO Racing Website http://tkocompetitiondev.com/
EDWARD2003 is offline   Reply With Quote
Old 01-04-2015, 04:13 PM   #713
blade072's Avatar
Trader Rating: 98 (100%+)
my kit one failed after 1 run (1 bearing fell out during the build and 1 after a slight off track excursion).........was told it was an out of tolerance issue... because both bearings fell out. i suggested they might want to change to the flanged bearing type setup...ie same as what xray did when they had the same issue.....anyway long story short, was replaced and i have not had a single issue since........i was going to do the washer thing also, but since having the replacement i have not needed too and still running flawless to date
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 01-04-2015, 04:18 PM   #714
blade072's Avatar
Originally Posted by EDWARD2003 View Post
cool product.....might have to get some but i will be trying these first.....will let you know how they go
http://www.speedyrc.com.au/RSD-Batte...0XRAY%20RSD056
David Randall
Old 01-04-2015, 05:38 PM   #715
Mine came apart too, but I applied red loctite and pressed it back in. Never came apart since.
inpuressa is offline   Reply With Quote
Old 01-04-2015, 05:58 PM   #716
might try that. dont think i have any red around. i have green and thats the penetrating stuff. it might work.
Old 01-04-2015, 09:31 PM   #717
zerius's Avatar
I used a countersunk washer with a .5mm shim to fix the problem.
Jeff G
zerius is offline   Reply With Quote
Old 01-04-2015, 09:59 PM   #718
^^^^^excellent idea. thanks.
Old 01-05-2015, 09:52 AM   #719
racer x 1's Avatar
Trader Rating: 27 (100%+)
are the aluminum chassis available to the public yet?
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-05-2015, 10:09 AM   #720
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Sure are...
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
