Old 11-25-2014, 06:47 PM   #571
why would you want to? its been proven the longer shocks and taller towers work better.
dragonracing is offline   Reply With Quote
Old 11-25-2014, 07:22 PM   #572
trigger's Avatar
Yes the 2013 shocks and shock towers will fit the 2015 platform. Feel free to use it as a tuning option as some do like the shorties as opposed to the long shocks regardless of what other may say.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 11-25-2014, 08:50 PM   #573
Each track and driver have different preferences. for example all the Yokomo team at the Japan AOC ended up running short shocks on the BD7 2015.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 11-25-2014, 09:23 PM   #574
Potoczak's Avatar
Trader Rating: 107 (100%+)
Just want to try them for high bite situations on carpet.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-25-2014, 09:42 PM   #575
Gridworks Racing's Avatar
Preach on Minh!
Options are good and what works for some may not work for others. I look forward to hearing your feedback as well Potoczak.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 11-28-2014, 06:28 PM   #576
Potoczak's Avatar
If anyone is looking for the ats upgrade kit gridworksracing.com has kits in stock at 20% off. Great deal on a awesome upgrade for the 2015 r10.
Pete Potoczak
Old 11-30-2014, 01:51 PM   #577
Trader Rating: 20 (100%+)
Default new to Arc
First time out yesterday with my new ats kit in stock and was 2/10th faster than my yokomo. This is a great car easy to drive fast and very consistent. Looking forward to more tuning time
Donny Banks is offline   Reply With Quote
Old 11-30-2014, 02:20 PM   #578
Potoczak's Avatar
Wow this is great news. What surface?? Ats kit installed??
Pete Potoczak
Old 11-30-2014, 02:33 PM   #579
Running on carpet with ats on car.
Old 11-30-2014, 02:39 PM   #580
Was cool to watch donny wheel the arc. I also got my arc feeling better with heinricks setup. Not sure what donny has done on his but its wicked fast!
Old 11-30-2014, 02:57 PM   #581
Can anyone tell me if the shock towers will fit my T4 '14.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 11-30-2014, 03:04 PM   #582
trigger's Avatar
I don't think the holes will line up as the T4 bulkheads are spaced closer together. Another note, the Xray t4 utilizes shorts shock while the ARC 15 uses long shocks so unless you also plan on getting longer shocks, i don't think this combination will work.
Minh Nguyen
Old 11-30-2014, 03:13 PM   #583
I use the long Nt1 shocks right now with the raceberry towers. I picked up another T4 and thought if the R10 towers would fit they would be easier to find so I could run my long shocks on my new car also.
Thanks for your help.
Old 11-30-2014, 03:28 PM   #584
trigger's Avatar
I have measure the distance between the bulkheads and they measure 22mm. Now you measure the distance between the T4 bulkheads and that might give you an idea whether they may or may not fit your application.
Minh Nguyen
Old 11-30-2014, 03:46 PM   #585
Mine is 19mm. Thanks for the help.
