Old 11-21-2014, 06:10 PM   #541
trigger's Avatar
This car is very robust so spares will probably never get used. I would get the DCJ front axles and another set of blue springs and focus on lightening the chassis up with aluminum bits like the turn buckles, spool outdrives, and ball studs. And also a set of alloy screws. Then you'll have a hot rod. The ATS is not a must but a great tuning option. I personally like the ATS set up.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 11-21-2014, 06:18 PM   #542
thought of some more hop ups. low fric belts and pulleys. clean the grease out of the bearings and use gravity rc anti gravity oil. i remove one of the rubber seals and place that side on the inside where no dirt will get to them. my car is very free rolling. most of the guys around the nw with these are using yokomo pink on front and blue rear springs.
dragonracing is offline   Reply With Quote
Old 11-21-2014, 06:34 PM   #543
Trader Rating: 27 (100%+)
Thanks for the quick replies guys! Doesn't the 2015 ATS version come with DCJs or did I read this wrong?
B5 | B5M | TC6.2
Hobbywing | Savox | Airtronics
RC.Jon22 is offline   Reply With Quote
Old 11-21-2014, 06:37 PM   #544
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
the ats kit comes with the double jointed front driveshafts
jeff jenkins is offline   Reply With Quote
Old 11-21-2014, 07:12 PM   #545
I believe the ATS kit comes with the front DCJ and the belt tensioner. Great value for the price. The ATS allows you to get any toe angle you need, and adjust how much additional toe you get while cornering. Great tuning aid. I haven't tested it yet, but hope to run it this weekend. The ARC spur is a bit different the rest, so I would also get the proper spurs for the gearing you need. As far as upgrades go, I highly recommend the low friction belts and the alum turnbuckles.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 11-21-2014, 07:28 PM   #546
I was told the spurs are the same as xray spurs. im running stock and use an 88. used it in stock and vta (scale spec).
Old 11-21-2014, 09:47 PM   #547
Logi Maker's Avatar
Trader Rating: 49 (100%+)
I broke a sway bar ball off of my front arm while popping it off during the build... DIALED!
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
Old 11-21-2014, 09:52 PM   #548
lbckevin's Avatar
Trader Rating: 85 (99%+)
Rookie..... LOL
Kevin Smith
Schuur Speed* Hobbywing * Pro-Line * MIP * Paint Monster Airbrushing * Schelle Racing
lbckevin is offline   Reply With Quote
Old 11-22-2014, 12:26 AM   #549
Best way to remove the cup off the arm is to twist it with a 2mm driver, while you have it loaded it'll flick off with a fingernail.
I have broken 2 in the past before I knew this little trick lol.
cyclonetog is offline   Reply With Quote
Old 11-22-2014, 12:28 AM   #550
Tandum4056's Avatar
Trader Rating: 95 (100%+)
What is a good starting set-up for 17.5 medium to high bite carpet on the 2015 without ATS? Would box set-up be OK to start with. It seems most set-ups I found are with the aluminum chassis which I do not have at this point yet.
Tandum4056 is offline   Reply With Quote
Old 11-22-2014, 12:33 AM   #551
Kit setup is definitely a good starting point, we're actually struggling to find anything better!
Old 11-22-2014, 09:09 AM   #552
stiltskin's Avatar
Trader Rating: 101 (100%+)
I just posted my Black Edition in the for sale forum if anyone is interested. Comes with lots of spares and low friction upgrades. Check it out.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 11-22-2014, 03:36 PM   #553
Trader Rating: 42 (100%+)
Anyone make a standard steel screw kit for the ARC? Non-stainless?
Aaron Moore
McFactory Motorsports, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 11-22-2014, 04:19 PM   #554
Potoczak's Avatar
Trader Rating: 109 (100%+)
What other springs are guys using besides the stock ones on carpet??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 11-22-2014, 06:04 PM   #555
trigger's Avatar
At the IIC, most the team were using at the new blues front and rear. Kody was using yok blues front and rears.
Minh Nguyen
