Old 11-05-2014, 07:55 PM   #451
Logi Maker's Avatar
Trader Rating: 49 (100%+)
The bench.
Maybe he is confused from posting in almost every thread on RC Tech.. LOL.
Serious note... I am slowly building my kit for asphalt season, 17.5, with exceptional guidance from ARC NW. I was going to run the 96 spur and ground down the "Flex Motor Tower" within like 1mm from the screw holes. Thought I had plenty of room but tried to put a 50 on there and no go..
Do we even need that part or shall I gind more...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 11-05-2014, 08:20 PM   #452
Logi Maker's Avatar
Just got a text from my Yoda and told me to grind to the screw!!!
Kyle Predmore
Old 11-05-2014, 08:28 PM   #453
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
You can use part # R102507 lower motor mount nut. Looks better! I just used a dremel and a grinding bit to ream the motor mount slots. I can get a 51t pinion in there with a 96t spur.
Josh-n-ya is offline   Reply With Quote
Old 11-05-2014, 08:32 PM   #454
not worth a response.
dragonracing is offline   Reply With Quote
Old 11-05-2014, 09:42 PM   #455
Logi Maker's Avatar
Kyle Predmore
Old 11-05-2014, 11:06 PM   #456
trigger's Avatar
I can see how a dremel can make the slots for the motor screws wider, or grinding the vertical stand on the flex mount will solve the clearance issue for the pinion gear. I do think having a slightly smaller spur gear like an 88 or even a 92 will also remedy the problem without grinding the nice aluminum.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 11-05-2014, 11:13 PM   #457
Moar teeth!
-Mike B.
Carnage9270 is offline   Reply With Quote
Old 11-05-2014, 11:19 PM   #458
+1
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 11-06-2014, 12:03 AM   #459
Logi Maker's Avatar
True that... An 88 will be money but will move the motor back very crucial mm that I will never notice... LOL. I ground it down and flat blacked it... looks factory. Still going to go with the 88 and claim lower rotating mass.
Kyle Predmore
Old 11-06-2014, 07:30 AM   #460
Josh-n-ya's Avatar
Don't shoot the messenger. Its only just another option. You can do what you like.
Old 11-06-2014, 09:22 AM   #461
88 works good. Been running it for a while. Yeah kyle less rotating mass
Old 11-06-2014, 10:15 AM   #462
I'm running a 92 for the most part. Can fit up to a 54 pinion in there after grinding a bit.
-Mike B.
Old 11-06-2014, 11:58 AM   #463
Originally Posted by nikos2002 View Post
Hoping boxes are delivered today -- we can get items in system later today or tomorrow.
are these in stock, yet?
thanks.
Colorado On-Road RC Club
www.5280raceway.com
www.facebook.com/CORtrack
Driving: Xray T4 2015, T.O.P. Rebel 12, Durango DEX8T, Durango DEX408 v2, Associated B5M, Associated B44.2
rc_speed is offline   Reply With Quote
Old 11-06-2014, 12:03 PM   #464
oh, I have another question, also.
I have the stock R10 2015 chassis on my car. I run only on carpet. I believe that stiffer is better on carpet. Is this true?
If it is true, I think the stock chassis is 2.25mm thick. Would the 2.5mm (Product Code: R108007) handle better?
I already use the chassis stiffener in the car.
I also don't want to go to the aluminum chassis because I am afraid of hitting something and bending it.
thanks,
tim
www.5280raceway.com
Old 11-06-2014, 12:16 PM   #465
trigger's Avatar
Looks like the ATS car kit is in stock but no signs of the the ATS conversion yet. Loads of Titan tools are in stock as well.
Minh Nguyen
