Advance R/C Car R10 2015 >
Old 10-27-2014, 08:28 PM
  #421
Trader Rating: 20 (100%+)
Mihn....I am almost done with the setup sheet....I need 5 more minutes!
Attached Thumbnails Advance R/C Car R10 2015-dimg_4188.jpg   Advance R/C Car R10 2015-aimg_4190.jpg   Advance R/C Car R10 2015-jimg_4187.jpg
Sean Williams is offline
Old 10-27-2014, 09:45 PM
  #422
Here is my setup.... Enjoy!
Old 10-29-2014, 02:14 PM
  #423
Nice clean builds Sean!
Kody
Kody is offline
Old 10-29-2014, 03:52 PM
  #424
Hi Sean
Thanks for posting the setup, what did you achieve by changing the rear lower shock position to the farther inboard position?
Besercoe is offline
Old 10-30-2014, 06:38 AM
  #425
Originally Posted by Besercoe
Hi Sean
The car was more responsive, I had better side bite, and the car seemed to turn better. I felt with the arms flipped "line/indicator" facing the center of the car with the mounting position all the way out, the dampening seemed to be almost hindered in a way and was not able to move up and down freely, almost like a slight bind, plus the car felt to me to be a little lazy. Not saying the other way is wrong, but for me what is shown in my setup worked really well.. The car is very responsive to changes which is good!
Old 10-30-2014, 01:14 PM
  #426
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Originally Posted by MrHighOctane8
More and more touring cars! (:
Josh-n-ya is offline
Old 10-30-2014, 02:14 PM
  #427
OK so im stumped. ran the car last night on carpet in stock 17.5 class. qts 32 tires are the tires we have to use in the class. car would have a little push upon entry then as the car slowed it would gain grip more and more thru the turn. so much so i would oversteer and turn in too much and hit the inside pipes. got pretty frustrated. stock setup in general but i have the 3.5 rear block with .5mm shim under only. split blocks on rear W/ notches out. front front block with 1.5mm shims split blocks also with notches in. other than that its the standard setup. car just has way too much steering. track is small and grip is high. our next run is sat on a larger track with the same basic layout but much higher speeds with med to high grip levels. i just ordered 5 of the 6 yokomo springs (orange was out of stock) and they should be here tomorrow i even paid for express shipping. hopefully the car will behave a bit better. car seems to just transfer too much weight onto the front as it slows and turns in very hard as the slip angle gets less and less. pretty frustrating. one of the guys said to try adding some ackerman to calm it down. i may do that. the steering just seems overly aggressive. it may be due to the slip angle being less with these tires.
dragonracing is offline
Old 10-30-2014, 03:41 PM
  #428
The high roll center in the front might be causing this. Try .5 shims in the front also. Too much pressure on front tires maybe.
inpuressa is offline
Old 10-30-2014, 04:24 PM
  #429
I will try that. It makes sense. thanks ill report back on sunday on results.
Old 10-30-2014, 04:30 PM
  #430
Might also want to try out Henrik's carpet setup he recently posted over at the FB arcdriver page
Old 10-30-2014, 04:50 PM
  #431
ill go take a look at that. on one track last weekend the car was ok. i was just over driving it a bit. then last night it handled like dog poo. now maybe on the big track it will be fine lol. one can only hope. but ill go look at that setup.
Old 10-30-2014, 05:02 PM
  #432
Great explanation thank you. I will give it a try
Besercoe is offline
Old 10-30-2014, 05:09 PM
  #433
Check your bumpsteer also...sounds like the car is slowing down, beginning to roll, and turning in harder.
barnacle is offline
Old 10-30-2014, 05:13 PM
  #434
Harder spring in the front and/or thicker diff oil would be some things I would try.
Govert is offline
Old 10-30-2014, 05:30 PM
  #435
yeah going to check all those. i run 5000k in the rear diff. will be reading my setup helper by martin crisp also. and funny i had that setup sheet from heinrik in my pit bag. never though of consulting that. going to try that setup for saturday and see how it goes. although i dont have those particular springs. i did order the yokomo springs -the orange spring thats not in stock. i express mail ordered them so i hope they show tomorrow.
