Old 09-21-2014, 08:29 PM   #241
Suspended
Oooh, ok thanks a lot man. I always wondered how you guys figure out the ratio
nene_805 is offline   Reply With Quote
Old 09-21-2014, 08:40 PM   #242
Suspended
Ooooh, ok. Thanks a lot man, always wondered how you guys figured that out
Old 09-21-2014, 08:56 PM   #243
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by dragonracing View Post
Just club racing. But. Tq and the win first time on carpet. Had to reverse my roll centers but car worked pretty well on carpet. tried the chassis stiffener for the carpet and its a bit much. really makes the cars steering very aggressive. had to remove the screw thru the upper deck to tame it down. i ended up reducing the amount of shims in the rear to .5mm under the rear toe block and increasing the shims to 1.5 mm in front. ended up taking away enough steering to really tame the car down. carpet is a totally different animal than pavement.
your saying you went with .5 shim under the rear toe block, and 1.5 under the front, front of what, front toe block on the front of the car or front toe block on the rear of the car. ---anti squat-- inquiring minds wanna know.. the rear of my 15 was unpredictable stepped out one lap and not the next. thought about some anti squat but robbed the gear diff outta the 13 to get the lighter weight oil and it didn't help... but alas,,, threw the alum chassis today so probably gotta get a whole new set up..
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-21-2014, 08:58 PM   #244
skypilot's Avatar
Originally Posted by Kody View Post
Last night was definitely a great start to the 2014/2015 carpet season in Seattle! Dragonracing's car in 25.5 Scale Spec (USGT and VTA mixed) was on point after a few changes and looked solid all night. Corner speed was up with the fastest Scale Spec cars I've seen to date!
My personal plans of running Modified were sidelined due to electronic problems. Carnage9270 offered up his fresh built 17.5 car with zero laps to wheel for the night. With running a track side shop I was left with zero time to take it for a test spin so Q1 off we went. Have to say it was one of the more impressive first battery runs I've ever had! Corner speed and grip were amazing. Other than kit setup I made a few quick changes to Ackerman, front toe and camber and she was stable/quick for the main.
Looking forward to getting back out learning more what this car is capable of!
Kody
little pissed off, no fair lapping me twice, that's total BS and will not happen again...
Old 09-21-2014, 09:19 PM   #245
Suspended
Is this cars gearing 48pitch?
Old 09-21-2014, 09:21 PM   #246
trigger's Avatar
the spur that came with the kit is 48 pitch.
Minh Nguyen
[Maclan Racing][Xpert]
trigger is offline   Reply With Quote
Old 09-21-2014, 09:31 PM   #247
sorry ritchie. i should have been a little more specific. so a .5 under the rear/rear toe block. and 1.5 under the front/front block. my car has split blocks front and rear. nothing under each of those. ill have a setup sheet up soon.
dragonracing is offline   Reply With Quote
Old 09-21-2014, 09:34 PM   #248
Suspended
Oh shoot. I ordered 64p gears
Old 09-21-2014, 09:35 PM   #249
Suspended
Will 64p gears work? If so what should i run for 17.5
Old 09-21-2014, 09:40 PM   #250
64 pitch is fine. much quieter anyway. more fine tuning with 64p. around a 3.7 to a 4.2. 88/47 is a good start. but get some smaller pinions also. say from 41 up to 47. then you can go from 4.29 down to 3.74. all depending on track size and temp. motor temps in the 130 to 160 range are perfect. any hotter and motors start to fade on power. i like to keep mine down to 130 ish.
Old 09-21-2014, 09:40 PM   #251
lbckevin's Avatar
Trader Rating: 82 (99%+)
They work fine...as long as you pair them with 64p pinions
Kevin Smith
Schuur Speed* Hobbywing * Pro-Line * MIP * Paint Monster Airbrushing * Schelle Racing
lbckevin is offline   Reply With Quote
Old 09-21-2014, 09:47 PM   #252
most racers use 64p. Just make sure you set the mesh properly. 48p is strong, but can't fine tune.
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 09-21-2014, 11:02 PM   #253
Josh-n-ya's Avatar
Trader Rating: 71 (100%+)
Im not sure if nene 85 understands all this gearing stuff yet? Maybe just safe to say get pinions for blinky starting at 45t through 55t. Then get spur gears 88t, 92t, 96t and get a gear chart to help with what to gear at. 64pitch is most common to use. Ask someone at your track who can show you!!!!
Josh-n-ya is offline   Reply With Quote
Old 09-22-2014, 07:32 AM   #254
88/52 largest gear combo you can put on the arc without hitting front motor mount. But getting from 45 to 51 and an 88 spurnwill suffice.
Old 09-22-2014, 07:55 AM   #255
Josh-n-ya's Avatar
You can use part# R102507 on the front of the motor mount to replace the one that gets in the way of pinions.
http://www.shopviperrc.com/ProductDe...ctCode=R102507
SEO by vBSEO 3.5.0
