Like Tree7Likes
Old 04-30-2016, 08:43 PM   #571
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
...also how are you lowering the rear pod to get a 5mm ride height with the -3.75 axle pills? I can only get 6mm ride height with 58mm tires.
Josh-n-ya is offline   Reply With Quote
Old 04-30-2016, 09:51 PM   #572
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Josh-n-ya View Post
What kind of rollouts are we talking 10.5 boosted? I got a 96 64p installed at the moment. That's also using 58 to 60mm tall tires.
45 to 50 should put you close.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 04-30-2016, 10:00 PM   #573
There are 4 of us with RK 10s here. We all have different layouts. Mine is set up for a square pack forward with electronics behind. Last week I ran a shorty transverse just in front of the electronics without changing anything else and no massive or even noticeable affect on steering.
Old 04-30-2016, 10:19 PM   #574
Josh-n-ya's Avatar
Thanks! What about the rear pod ride height? How are you guys getting 5mm ride height with what pill insert?
Old 05-01-2016, 06:52 PM   #575
Don't laugh, we run them high. On a new set of tires I'm at 7mm rear, 6mm front. As the CG is all under the axles and the car is planted, there are no negative effects. We did this as we are in a club and cheapskates by nature. You could ask Bruce for some of the Four-R rear shims. And that would drop it right to 5mm.
Old 05-01-2016, 07:00 PM   #576
Trader Rating: 28 (100%+)
What did I tell ya on the ride height Josh. Especially at WSR what he says makes sense.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-01-2016, 07:53 PM   #577
Josh-n-ya's Avatar
Yup. Good to know! Whatever works I'm on board.
Old 05-16-2016, 09:26 PM   #578
Josh-n-ya's Avatar
Had my first run with this badboy this past weekend. Most fun Ive had in a long time out on the track. I had some minor issues and those were my fault. I had a cheapo motor fan mount that kept sliding around and kind of prevented the pod from having smooth movement. Got a R1 fan mount coming. I had a shorty battery mounted forward and esc/rx in back close to pod. It was ok for the most part but was lacking punch throughout the run with a shorty. Going to try a stick pack in the middle next time then maybe some saddles later. Cheap Rc4Less tires purple fronts and pink rears gave plenty of traction. Will post up pics soon.
Old 05-16-2016, 09:44 PM   #579
1spunspur's Avatar
What track surface are you running on and where is that track.PLS.
P./
1spunspur is offline   Reply With Quote
Old 05-17-2016, 06:47 AM   #580
Josh-n-ya's Avatar
Huge asphalt track. Warm Springs in Fremont CA!
Old 05-17-2016, 08:34 PM   #581
1spunspur's Avatar
When are they running next , and when is it open for practice?
P./
Old 05-17-2016, 08:45 PM   #582
They are running this Saturday and the 11th of June. Practice is only on raceday.
Team I'm Over It
Old 05-17-2016, 08:51 PM   #583
1spunspur's Avatar
Thanks, still trying to get mine race ready. I've been trying to get over there but things have been changing on me on a daily basis.
P./
Old 05-31-2016, 01:59 PM   #584
Default Mounting the body
So I've noticed the Saxo body sits about 7mm high then the chassi with new full size tires. I have to use the provided spacers on the posts to keep the front of the body off the tires. Just curious if it's a problem with the chassi being below the body line. But the body is level with the front bumper.
jake alton is offline   Reply With Quote
Old 05-31-2016, 02:35 PM   #585
Josh-n-ya's Avatar
What's the size mm of your tires in front? What brand? I'm using rc4less and I trued front down to match rear 58mm. The front tires were way too tall for that body. Hope that helps.
