Like Tree7Likes
Old 04-04-2016, 08:39 AM   #541
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Time to put Thunder and Lightning back on the track.
Thunder: 13.5 boosted 2S.
Lightning: 4.5 mod 1s.
Both need some track time love. Also need thinking of making a wet weather car out chassis #3. Tired of looking at it stripped to spares in my parts bin.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 04-04-2016, 08:43 AM   #542
jetnjme's Avatar
thanks John. seems i should take up stock in a pinion / spur manufacture
I order up another batch soon
Northern California Pan Car Revival
jetnjme is offline   Reply With Quote
Old 04-04-2016, 08:44 AM   #543
jetnjme's Avatar
10.5 blinky 2s, maybe call her "Rain Storm"
Old 04-04-2016, 08:47 AM   #544
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by jetnjme View Post
they felt good, I liked the front, steering was nice, as I don't like a lot of steering. the rear could have been a little softer but it worked. It did slide out coming onto the straight and a few other corners but only if you got on it real hard, nice and smooth it did good, once i got a rhythm going, only sauced one time in the morning, was able to get three runs in.
I had the kit springs (side 18) and 30k in the tubes. think I'm going up to 50k and ordering the 22 24 tweek springs, felt a little soft but the front I'm going to leave for now
Good info, sounds like fun
Also, look into 700cst shock oil, I noticed this settled my RK down nicely
Heavier side springs have a notable impact on turn in, and center out, heavier is always less side grip, from my testing.
I'm using SpeedMerchant Blue spooge (Thick) with .024' side springs, but for asphalt I think .020 with green, green/blue would work too
You don't have to use the same lube in both side dampers
She's pretty much called "RoadHog" at our carpet track
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-04-2016, 08:55 AM   #545
jetnjme's Avatar
we need to patent our car names, Roadhog, thats a good one.
Once the 20's are back in stock, I try the SM spooge also
Old 04-04-2016, 09:15 AM   #546
Nice. I gave mine names last year being sarcastic.
Old 04-08-2016, 11:56 PM   #547
Went back and looked to see what spur gear sizes actually fit on the RoadKill
96-100t 64p are the largest size that will work for proper rollout, with 51-56mm tires running 10.5 2s approx 35mm rollout
This should also match up with 1s mod winds, should anyone choose that route
Old 04-13-2016, 09:46 AM   #548
Put mine down on the rug last night for the first time this year. What a thrill. 13.5 2S boosted and it just plain works. Time to paint a new body and have some summer fun with the go fast car!
Old 04-14-2016, 11:59 AM   #549
celt's Avatar
Default IIC 2016
Hey Fellas,
Looked a few posts back and didn't immediately see the answer...
If Scotty is going to run a 235 class, anyone hear what the motor/power arrangement would be?
I recall 1S/10.5?
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-14-2016, 12:06 PM   #550
TOADYY's Avatar
Send a message via AIM to TOADYY
It might be 2S/10.5 with spec tires
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 04-14-2016, 12:11 PM   #551
celt's Avatar
Thanks TOADYY,
I might just make the trip to run this class. Wow, would that be fun.
Stan Garvin
Old 04-14-2016, 12:28 PM   #552
Originally Posted by celt View Post
Thanks TOADYY,
Its a LOT of fun
Old 04-14-2016, 01:54 PM   #553
celt's Avatar
Originally Posted by RedBullFiXX View Post
Its a LOT of fun
I dig 1/12 scale...but Pro10?
The bubble in my gum.
Stan Garvin
Old 04-14-2016, 02:19 PM   #554
Trader Rating: 46 (100%+)
It would be an honor to be on the same track as RedBullFiXX.
Its a LOT of fun
v_squared is offline   Reply With Quote
Old 04-14-2016, 03:45 PM   #555
LonnyJ1950's Avatar
Nah, been there, it's mostly an exercise in dodging.
Lonny
LonnyJ1950 is offline   Reply With Quote
