Like Tree6Likes
Old 10-03-2014, 11:41 PM   #331
Pro10noob's Avatar
Peugeot 905HD
Corally Nissan P35
Mix Nissan
Mix Mercedes C11
Mix Porsche
Or for extreme downforce the Lola bodies.
Tires tarmac: BSR double purple front and purple rear.
You can use those on carpet 2 but watch the front side for gripp rolls.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 10-04-2014, 12:00 AM   #332
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
Default pro10
What bodies work well for a medium asphalt track like calraceway or camarillo? (Never been to camarillo before)
lagcisco is offline   Reply With Quote
Old 10-04-2014, 12:38 AM   #333
TOADYY's Avatar
Send a message via AIM to TOADYY
Hot Bodies Toyota GT1 or Protoform Peugeot 905b medium down force if you can find them (I currently have both)...good luck. You can get the 905b high downforce.
http://racepf.com/on-road-1-10-1-12/...ht-clear-body/
I think McAllister still makes some bodies or you could get a 1/10 nitro GTP body.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is online now   Reply With Quote
Old 10-04-2014, 06:37 AM   #334
OrganicMechanic's Avatar
Trader Rating: 34 (100%+)
For carpet I use BSR Purple(GT Spec) fronts for just about any traction level. For rears, depending on traction, BSR XX Pink for med. traction or BSR Pink for low traction. YMMV.
OrganicMechanic is offline   Reply With Quote
Old 10-04-2014, 07:18 AM   #335
RedBullFiXX's Avatar
If you are going to run at Camarillo, check with the locals there on which tires to use
For sure, purple do not work there, or Lilac, or Team purple...
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 10-06-2014, 01:50 PM   #336
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
That is a lot of failed tires. Anyone try Xceeds out there on the asphalt yet?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 10-06-2014, 02:30 PM   #337
I think they run the softest version of white rear, on 1s 10.5 open
It's a smooth sealed asphalt surface track out there
Old 10-06-2014, 03:24 PM   #338
Pro10noob's Avatar
Correct me if i am wrong but isn't white a carpet tire??
Isn't pink at the rear a option to get some grip?
Or Xceed soft, that is 25 shore
Regards Roy
l===/o\===l
Old 10-06-2014, 09:57 PM   #339
Regards Roy
Anything from the pink family just slides, no grip at all on this surface
Synthetic rear are a must
Old 10-06-2014, 11:22 PM   #340
Pro10noob's Avatar
OK and white is what shore???
Regards Roy
l===/o\===l
Old 10-07-2014, 04:51 AM   #341
celt's Avatar
Regards Roy
http://johnsbsrracing.com/foam-tires/10th-scale-foams
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 10-07-2014, 04:56 AM   #342
Regards Roy
White and Pink both duro @ 30-35. However Pinks have "Low wear/longer lasting characteristics".
Whites wear FAST and lay down more traction then Pinks. Whites can feel squirmy under power once they warm up because of this. Where as Pinks feel more solid, less side wall give and wear like iron compared to Whites.
I'll assume the Whites work better then Pinks on the smooth sealed asphalt surface he described because of the characteristics listed above.
On carpet when the track is "green", White or Pearl-White/White feel good until the traction comes up then the Pinks feel perfect.
Hope that explanation helps.
Old 10-07-2014, 04:59 AM   #343
Turbo Stan sneaks in a reply as I type mine lol! Fast off and on the track!
Old 10-07-2014, 05:41 AM   #344
Organic Mechanic, everything you ever wanted to know about foam compounds and their designations can be found here. When CRC put this one together, the author did a great job of describing not just the shores, but the wear characteristics based on the chemical makeup of the foam itself.
Old 10-07-2014, 06:23 AM   #345
That was a good read!
Where do Xceeds fit into that? are they European/Italian?
