Old 08-23-2014, 10:58 AM   #271
Pro10noob's Avatar
I believe it was 0.5MM carbon.
Have to ask tho.
Regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 08-23-2014, 11:02 AM   #272
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by liljohn1064 View Post
Just thought I'd post some thoughts here and my setup.
Chassis: SpeedMerchant Roadkill 10
Tires: Double Purple Front, Double Pink Rear 61mm or 2.4 inch OD UNCUT
Ride Height: 8mm (please don't laugh)
Body: Protoform P905b, no side air dams
Bumper: Parma Ultimate cut to fit the P905b body
Center shock: gold spring (5 lb) with 40 wt Losi Silicon, 2 hole piston
Rear droop: 2mm
Pod sag: less than 1mm
Front droop: .5mm
Spur: 75 tooth 48P
Pinion: 19 tooth 48P
Rollout: 48.5
Caster: 4*
Camber: -.5*
Front spring: .20
Battery: Turnigy 6400mAh Ultimate
ESC: Tekin RS Gen 2
Radio: KO Eurus w/210S receiver
Servo: JR3650 mounted with no spacers with screws in top holes of the servo mount.
2 1/4" Turnbuckles are mounted to the front of the Kimbrough medium servo saver. The ballstuds are on the inner holes of the servo saver arm. Turnbuckles are swept back from inside to outside, about 1cm difference. The turnbuckles are flat went viewing from the front. No noticeable bump steer.
All weight is under the center line of the rear axle visually.
The only thing above the tire tops are the rear body posts.
Car does not over or under steer at this time.
Corner rotation is perfect.
Diff will bark a little in tight corners when trying to rapidly accelerate.
Complaints: none
Issues: More advanced driver states steering balance between into and out of corners could be better. Right it's better in than out. Might need a stiffer front spring or ackerman change. This would lead to perfection.
Solution: Just drive it and drive it a lot.
From the Pro10 page.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 08-23-2014, 12:06 PM   #273
celt's Avatar
The Roadkill is so stable it might just be the pinnacle of pan car racing.
The chassis is just sick, period.
If you can't get this thing around the track like a rockstar, just sell your stuff - this hobby isn't for you.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is online now   Reply With Quote
Old 08-23-2014, 06:52 PM   #274
Does anyone have an exploded view of the Roadkill shock ???
THEBIGBULL is offline   Reply With Quote
Old 08-23-2014, 06:57 PM   #275
John Higgins
Old 08-23-2014, 11:24 PM   #276
TOADYY's Avatar
Send a message via AIM to TOADYY
I finished and ran my RK10 today . This bring back a lot of great memories of racing Pro 10 at SoCal R/C raceway (RIP). It definitely is fast with a 2S and 17.5. Stilling need to dial it in. It should be a 8.8 sec car when dialed. In the hands my buddy Ray he did a 9.2 fast lap. Will post my set-up when I get tuned just right. People eye brows were raised seeing this car run and I know Ray will be buying one when they are available again. I really think we will be getting a class started at TQ. Here is some pics:
Speedmerchant Roadkill 10 235mm Pro10 Pancar-img_20140823_170819.jpg   Speedmerchant Roadkill 10 235mm Pro10 Pancar-img_20140823_170803.jpg
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 08-23-2014, 11:25 PM   #277
TOADYY's Avatar
And a couple more pics
Speedmerchant Roadkill 10 235mm Pro10 Pancar-img_20140823_165724.jpg   Speedmerchant Roadkill 10 235mm Pro10 Pancar-img_20140823_165645.jpg
Old 08-24-2014, 04:23 AM   #278
Looks great! How does it feel?
John Higgins
Old 08-24-2014, 08:30 AM   #279
OrganicMechanic's Avatar
Trader Rating: 25 (100%+)
Nice build TOADYY. Which body is that?
GT12- Schumacher Supastox GT
MARCCA Member
OrganicMechanic is offline   Reply With Quote
Old 08-24-2014, 10:00 AM   #280
Pro10noob's Avatar
It looks like a Toyota.
Regards Roy
l===/o\===l
Old 08-24-2014, 10:11 AM   #281
TOADYY's Avatar
It felt great but still need to dial it in. I'm running spec tires, .017 front springs, red center spring, 40wt. oil, kit rear side springs, shurr speed 17.5 with a rollout 79.64mm.
It's fast on the straight but a little slow in the in-field. I think if go down on the timing is could get it where I want. I also need to make some adjustments to the esc and add drag break. Over all I am very happy with it.
The body is a Hot Bodies Toyota GT1.
Old 08-24-2014, 10:25 AM   #282
celt's Avatar
A diffcult to find body indeed.
Stan Garvin
Old 08-24-2014, 10:33 AM   #283
TOADYY's Avatar
Yes it is, unless you have friends that have kept it all these years. I also have a Peugeot med. downforce
Old 08-24-2014, 10:40 AM   #284
TOADYY's Avatar
I wonder if this is the same body...hmmm http://www.rcplanet.com/HPI_Toyota_G..._p/hpi7581.htm
Old 08-24-2014, 11:05 AM   #285
TOADYY's Avatar
Ok I just measured mine to compare the specs on that website and the one on the website is bigger
SEO by vBSEO 3.5.0
