Like Tree12Likes
Old 08-14-2014, 11:29 AM   #181
OrganicMechanic's Avatar
Trader Rating: 35 (100%+)
Boosted 17.5 for now. The car is balanced fairly well with some pinecar weights. It still needs a caster and camber check.
Nice John! Bumper looks good, is that the Parma universal front bumper cut to fit? What brand/rating is that brick pack? 17.5 just for testing? Lots of questions I know...
OrganicMechanic is offline   Reply With Quote
Old 08-14-2014, 12:24 PM   #182
liljohn1064's Avatar
Trader Rating: 17 (100%+)
It's half a Parma universal sectioned at an angle the long way, so I get 2 from each block. It's notched to fit the body. Brick pack is the new Hobbyking 6400 90C. I wanted the capacity, just in case. The 10.5 went up in smoke last night when testing the controller after a lot of cogging Tuesday. I might have to switch systems as I think my ESC is bad too. I put in the 17.5 to test and it's cogging. RMA is ready.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-14-2014, 12:30 PM   #183
Originally Posted by howardcano View Post
Very pretty!
Is that antenna connected to a 27MHz or 75MHz receiver? If so, you have even more of my respect and admiration.
No , it's to a KO. I do have a working Airtronics Cailber 3PS 27MHz and Novak receiver in the basement.
Old 08-14-2014, 03:01 PM   #184
It looked like you had fitted it to the body contour, should help protect the body nicely! I did see your post about the 10.5 just wasn't sure if it was pronounced dead yet lol. With ratings like that the Hobbyking battery should feed a 10.5 nicely!
Old 08-14-2014, 06:44 PM   #185
I just called a little audible. In my pile of spares, I had a brand new Tekin RS Gen 2 and ThunderPower 13.5. Now installed. 20* on the motor, timing profile 3 on the speedo to test. Yep, I have rip. This car will not need a 10.5 indoor.
Old 08-14-2014, 07:12 PM   #186
celt's Avatar
Default servo
heads up...
I'm not sure you can run a standard sized servo on the chassis - I couldn't see a way to get things aligned.
No biggy, most have mini servos from old 1/12 pancars laying around.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 08-14-2014, 08:10 PM   #187
That'll do no doubt.
If we ever get outdoors I'd like to run a nitro lola body and a 3-5T lol... ya I'm aware I have a problem.
Originally Posted by celt View Post
heads up...
Is it an issue of being too wide for the mount holes to line up, or an issue of the servo gear not being @ center line when mounted? I'm always curious...
Old 08-14-2014, 08:11 PM   #188
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
What's the lid for that body? looks like an excellent paintjob
trackdesigner71 is offline   Reply With Quote
Old 08-14-2014, 08:26 PM   #189
Unfortunately My axle set has been sent to Austria instead Australia so i have another delay.
hydro111 is offline   Reply With Quote
Old 08-14-2014, 10:17 PM   #190
Still waiting
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 08-14-2014, 11:19 PM   #191
Post
Originally Posted by RoyU View Post
Still waiting
Me too....no shipping notice yet!!!!!
THEBIGBULL is offline   Reply With Quote
Old 08-15-2014, 05:12 AM   #192
celt's Avatar
Kind of both really.
Bit narrow to fit standard servo in one location, but if you did get it to fit, it would be 1/2" off center.
I just gave it a go, clearly it was drilled for a 1/12 pancar mini servo that you could flip for weight bias.
Eventually looking at this...
http://www.shop.kopropoamerica.com/i...roduct_id=1491
Stan Garvin
Old 08-15-2014, 06:39 AM   #193
Protoform P905B.
Old 08-15-2014, 06:43 AM   #194
That's a heart breaker! Hope it gets straightened out quickly.
Still waiting
It is very hard to be patient. Very.
Old 08-15-2014, 06:50 AM   #195
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
A $50 Futaba 9650 servo should be plenty for the job
Add a Kimbrough Med servo saver and you're good to go
http://www.apexrcproshop.com/index.p...roduct_id=1884
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
