Speedmerchant Roadkill 10 235mm Pro10 Pancar >
Like Tree65Likes
Old 08-11-2014, 12:44 PM
  #151
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by SpeedMerchant
Hi Guys,
Hope everyone had a nice weekend.
The rest of the RoadKill 10's are going out this week.
Our friend Arnaud from PetitRC did a set-up sheet for the RoadKill.
http://www.petitrc.com/reglages/spee...chantRK10.html
Have a great day.-Bruce
Very cool! Saved and ready to use.
liljohn1064 is offline
Old 08-11-2014, 09:32 PM
  #152
celt's Avatar
Originally Posted by liljohn1064
It's at the post office.... Delivery tomorrow.
In my grubby little hands...Muuuuhhaaaaaaa
Off the freak'in hook Bruce!!
Stunning!!
celt is offline
Old 08-11-2014, 10:28 PM
  #153
Pics!
hydro111 is offline
Old 08-12-2014, 07:41 AM
  #154
trackdesigner71's Avatar
Get that build done man!
trackdesigner71 is offline
Old 08-12-2014, 08:44 AM
  #155
celt's Avatar
Well...the chassis came built save the mono-shock and damping tubes.
celt is offline
Old 08-12-2014, 08:59 AM
  #156
something like..... This!
Old 08-12-2014, 09:39 AM
  #157
Mounted servo, servo saver, needs 4-40 or other inner ball stud. I used 1/4" flathead screws over the 1/8" screws included.
Mounted brick battery stop forward. Battery will still need tape to secure it.
4-40 cap head screws needed for rear axle. I have CRC/Associated aluminum in at the moment, but have stainless ready to go in.
Need to build the shock, lube and mount the side dampers, mount the front bumper and fit a foam protector, slip in the rear axle and mount electronics and fit a body.
The RC Screwz Gen X 10 kit is coming in handy!
Old 08-12-2014, 10:33 AM
  #158
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
Guys, make sure you check the caster on that front end
It is assembled, but not normally set to the 4' standard
Have fun
RedBullFiXX is offline
Old 08-12-2014, 11:17 AM
  #159
Need to raid my CRC stuff for bearings and shims for front and rear. Can't really put the rear in without shims. Shock is built and installed with 40 wt. Losi oil to start. Battery is taped in, but still loose side to side. Damper tubes next with 20k CRC lube to start. I need 8mm motor screws too!
Old 08-12-2014, 11:19 AM
  #160
Have fun
Thanks! Then, the first thing to check is caster, going to try 7* to start.
Old 08-12-2014, 02:30 PM
  #161
OrganicMechanic's Avatar
Trader Rating: 35 (100%+)
Beautiful machine, can't wait to see it burn'n foam down the straight!
OrganicMechanic is offline
Old 08-12-2014, 07:30 PM
  #162
So the kit came with no front or rear bearings?
hydro111 is offline
Old 08-12-2014, 09:48 PM
  #163
Exclamation
Mine has not been shipped yet!!!!! . I'm really really turning GREEN
THEBIGBULL is offline
Old 08-12-2014, 10:04 PM
  #164
You will need shims, 1/4 and 1/8.
Front bearings 1/8 inch ID FLANGED: 4.
Rear bearings 1/4 inch ID: 2 flanged, 3 regular.
Turnbuckles, 2 1/4 inch Lunsford work great.
Lunsford or Associated regular or long 4-40 ballcups.
Associated 1/4 inch ball studs 4-40 thread: 2.
A spur gear.
Diff balls and rings come with the axle kit from IRS.
Shock oil.
Damper tube grease.
Tires.
Old 08-12-2014, 10:08 PM
  #165
I made several parade laps. Need to shorten the wires, put on body posts, mount the custom foam bumper and fit a body to finish. Then it's off to the tweak station. Then video time!
