Old 07-12-2014, 11:49 AM   #16
I thought you weren't supposed to free rev the motor.
Razoo is offline   Reply With Quote
Old 07-12-2014, 12:01 PM   #17
vivo quevas's Avatar
Trader Rating: 18 (100%+)
A 17.5 or 21.5 reving the motor in the car won't over rev it. That's with a 4 wheels on the car.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 07-19-2014, 02:40 AM   #18
YoDog's Avatar
Trader Rating: 26 (100%+)
A higher turn motor is not likely to over rev and lead to rotor damage. A low turn motor is a different story though. The rotor is the victim in this scenario and is basically the same in all modern race motors. A low turn stator will spin the same rotor much faster than a high turn stator. Free running a given motor is relative to the potential RPM the stator can induce. Therefore a 17.5t will never induce enough RPM to damage a quality rotor that normally would see higher RPM in a 4.5t, even under load.
If you are still concerned, use a 1 cell battery or an adjustable DC power supply.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 11-29-2014, 01:49 AM   #19
Originally Posted by PROMODVETTE View Post
When shimming the rotor, is it best to get it as close to the sensor board as possible or are you looking for the magnetic center (is that what its called?) like brushed motors like?
Like to know too. Seems you can only get one or the other. When I try to center the rotor in the magnetic field, it's like 2+mm away from the sensor, which is not optimal...
redbones is offline   Reply With Quote
Old 11-29-2014, 02:57 AM   #20
Roelof's Avatar
Send a message via ICQ to Roelof
Zero timing + 10 degree
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is online now   Reply With Quote
Old 11-29-2014, 03:29 PM   #21
big al's Avatar
Why is that not optimal?
TA05 gen 1.... the real OG.
I'm not a racer, I just crush a lot.
17.5- Spec-r S1~ Scale Spec- VBC Ghost EVO ~ GT2- TA05 ~ GT3- TB03 ~ F1-F104
Keepin' it real with my M11x
big al is offline   Reply With Quote
Old 11-29-2014, 04:10 PM   #22
The general rule of thumb is to get the rotor about 0.8-1.0mm from the sensor board. If it's too far, it's said that you lose torque. But on some motors, when you shim it this way, you can't center the rotor in the magnetic field. This will cost you some rpm loss since there will be constant side pressure on the bearing.
It'd be nice if someone can make a depth adjustable sensor board.
Old 11-29-2014, 06:45 PM   #23
howardcano's Avatar
Trader Rating: 35 (100%+)
Why would it affect torque?
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 11-29-2014, 07:32 PM   #24
Not sure of the mechanics behind it, but I read this:
http://speedyrc.blogspot.com/2013/11...otor-open.html
Old 11-30-2014, 04:02 AM   #25
howardcano's Avatar
Thanks for the link. Unfortunately there was no explanation given.
Until I hear some logical reasoning, I would not give any credence to this claim.
Howard Cano
Old 11-30-2014, 11:06 AM   #26
big al's Avatar
Agreed. Until I find some info that is fact based, I'm just gonna give the rotor a little room to find itself, like a teenager....
Old 12-01-2014, 01:55 AM   #27
Skiddins's Avatar
When I've had a rotor that was a bit far from the sensor board it seemed more likely to cog etc.
If you have problems with the rotor not being anywhere near centre of stator or near the sensor board you need to buy a decent motor instead
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-01-2014, 02:43 AM   #28
niznai's Avatar
The way I see it, if the sensor is too far, it won't read as accurately the rotor position, hence wrong timing might be applied.
Skiddins' post above tends to suggest that if the rotor is too far away the ESC will go into sensorless mode hence the cogging (or apply the wrong timing with the same outcome).
Buy like he says a decent motor or mess with yours (machine the housing down a bit so you can center it whilst bringing it closer to the sensor board - fun!).
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
