Like Tree1Likes
Old 08-11-2015, 08:24 AM   #1471
Trader Rating: 33 (100%+)
in my ebuggy.. i use deans.. i havent gone with EC5 yet.. thinking about it.. i had a speedo burn up because the wires came unsoldered from the deans on the ESC side..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 08-11-2015, 10:09 AM   #1472
Has anyone experienced a twisted Rear Arm? Not sure if this is a bad mould or accident damage
charl is offline   Reply With Quote
Old 08-11-2015, 11:40 AM   #1473
Trader Rating: 12 (100%+)
You guys realize that this electrical connector talk is irrelevant to the car right?! And I'm not saying that I've never plugged anything in backwards but try not to make it so complicated....
banzaii is offline   Reply With Quote
Old 08-11-2015, 11:55 AM   #1474
they were all good suggestions.. most of which i had done already.. shorter wire so i cant cross over.. this is a forum for everyone..
Daniel Grobe
Sponsors:
Old 08-11-2015, 12:27 PM   #1475
Originally Posted by Skiddins View Post
If you look at my post I mention that the Deans packs are wired internally, i.e. I was only talking about prewired packs.
The 4 or 5mm tubes (by the way, every time SMC have tested them, 4mm show lower resistances than the 5mm, strange but true) have to be held in position somehow, this always used to involve the tubes being mounted on a PCB at the end of the pack.
When I first started buying Thunder Power packs (nearly 7 years ago) I spoke to Jim Skinner who asked why UK drivers wanted 4mm tubes on their packs when Dean's packs had lower resistance. He also asked if they would sell more if they were fitted with 4mm tubes and I replied yes. So they started shipping lipo's with the 4mm tubes.
If you use deans then your surface area is less than EC4 or EC5 plugs, this means smaller surface more heat is building up solder is not like this very much.
It is important to keep the solder in solid state thus keep the plugs cool.
The resistant value is for mod a bit less important as for stock(less amp)
eded1 is offline   Reply With Quote
Old 08-11-2015, 04:21 PM   #1476
Surface area is not the only factor that affects resistance.
EC4 and EC5 are easier and quicker to make compared with Deans which is why they have become popular.
As per Skiddins post 4mm bullets can have lower resistance than 5mm.
My own tests show Deans to be better than 4mm bullets but not as good as 5mm bullets but the 5mm bullets need to be very very tight to provide lower resistance than 4mm bullets and Deans.
DamianW is online now   Reply With Quote
Old 08-11-2015, 11:06 PM   #1477
My t4 15 goes great with progressive suspension and floating steering conversion on high grip carpet.oh and yes bullet plugs with negative terminal very short.
thomasd is offline   Reply With Quote
Old 08-12-2015, 02:02 AM   #1478
Skiddins's Avatar
Never known that on any Xray!
Is it graphite, hard or medium compound arm?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-12-2015, 02:09 AM   #1479
T4 15 Hard arms. Put the arm on flat surface and it rocks. About an 1 deg of twist.
Old 08-12-2015, 08:31 AM   #1480
erchn's Avatar
Agreed, are yah sure it's not a bent pin? Sometimes you can't tell its bent even from rolling it.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 08-12-2015, 12:26 PM   #1481
For me it counts for lower temps thus bigger contact area for mod.
My friend Jilles use Deans for mod he can deal with it but he can drive with such a smooth throttle finger, something i can't.
Old 08-15-2015, 11:31 AM   #1482
changing to -.75 hexes all round and thinner rear diff oil? will this give more rotation?
prodriver is offline   Reply With Quote
Old 08-15-2015, 11:37 AM   #1483
wtcc's Avatar
Try the -.75 hexes for the front only.
This will help corner entry to middle.
A too thin rear diff oil will hurt your exit.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 08-16-2015, 07:41 PM   #1484
RCRjuanabbe's Avatar
Any word on the 2016 T4-5?
RCRjuanabbe is offline   Reply With Quote
Old 08-16-2015, 08:09 PM   #1485
OttoKrosse's Avatar
After scanning about 20 pages I gave up looking for sway bar advice and decided to ask.
Recently bought my T4 2015 from a guy that ran it at 1 race event, so the car looks new and came with a few mods already done.
Would like input as to what size bars are being used on medium grip parking lot asphalt that is not perfectly smooth, running it in 17.5 TC class. I see the dots on the bars and not sure what sizes they are, currently has the 3 dot bar on the front and the 2 dot bar on the rear. If those are stock bars I may want to increase the size on the front and move the front bar to the rear.
Was running an Associated TC6.2 using one size larger bars on both front and rear than the assembly manual suggested and it was working.
Any input will be helpful, thanks in advance.
This space for rent.
Oo=00=oO
OttoKrosse is offline   Reply With Quote
