Like Tree1Likes
Old 08-10-2015, 10:46 AM   #1456
Trader Rating: 20 (100%+)
Originally Posted by dgrobe2112 View Post
quick question.. what are yalls opinions on battery plugs.. i been using the bullet connectors for my touring car.. i use deans plugs in all other cars.. i popped my ESC this weekend.. cuz the orca batteries are able to be flipped over.. and plugged in backwards.. so.. i was thinking of using plugs to prevent this in the future..
I avoid batteries that are either opposite my normal packs or that you can flip over and reverse the plugs for this reason. Just not worth the risk IMO.
As far as plugs go, I'm sure for most applications they are just fine but I do like the security that the bullets have when you plug them in. I don't think I've ever seen once come unplugged.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-10-2015, 10:57 AM   #1457
Trader Rating: 13 (100%+)
I use some cheap red paint and paint my batteries on the corners around the plugs. I have some batteries in which the post goes all the way through and I just be sure to paint both sides.
This way I can clearly see which is positive.
tim
Colorado On-Road RC Club
www.5280raceway.com
www.facebook.com/CORtrack
Driving: Xray T4 2015, T.O.P. Rebel 12, Durango DEX8T, Durango DEX408 v2, Associated B5M, Associated B44.2
rc_speed is offline   Reply With Quote
Old 08-10-2015, 01:32 PM   #1458
Trader Rating: 33 (100%+)
ok, thanks for yalls input.. i do have the wires set so one wont reach the other.. i think plugging the opposite side would be a good idea.. the Orca look same both ways.. cuz the tape on the side.. not on top.. thanks again.. i might just fill solder on one side.. lol.
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 08-10-2015, 03:17 PM   #1459
SpidarX's Avatar
I put a piece of black electrical tape over the terminals on one side of the battery. That way, I always place that side of the battery down, and thus the positive and negative terminal are always in the same location/orientation.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 08-10-2015, 04:40 PM   #1460
Deans plugs are great, infact better in performance than bullets but not as neat.
DamianW is offline   Reply With Quote
Old 08-11-2015, 01:32 AM   #1461
Cover the terminals on the unused side with tape and cut one wire short so it will only reach one terminal. No more costly errors
markrobinson is offline   Reply With Quote
Old 08-11-2015, 05:11 AM   #1462
not for mod tc
eded1 is offline   Reply With Quote
Old 08-11-2015, 05:38 AM   #1463
Originally Posted by eded1 View Post
not for mod tc
Deans are better in mod but irrelevant provided they don't get hot as there is power to spare.
Old 08-11-2015, 05:42 AM   #1464
Salkin's Avatar
Why are they better in performance, and why, then, doesn't the pro drivers use deans?
And when we drove 1/8 scale off road E buggies deans were never used, EC5's were the favorite connectors.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 08-11-2015, 06:16 AM   #1465
Skiddins's Avatar
I think it's partly to do with how the wires are connected inside the packs themselves.
Deans wired packs have their wires attach directly to the cells, where a lot (though I believe not as many any more) of the stick poacks used to have to have a PCB at the end of the pack soldered on the cells, then the tubes soldered onto the PCB, so two solder joints instead of one.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 08-11-2015, 06:16 AM   #1466
theproffesor's Avatar
Trader Rating: 57 (100%+)
Question? Unless the battery is prewired with Deans plugs, how are they more efficient? You still have the bullet style connector in the battery on the Deans pigtail.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-11-2015, 06:19 AM   #1467
Salkin's Avatar
Good point!
Old 08-11-2015, 06:27 AM   #1468
Salkin's Avatar
Why can't a normal hard case lipo with let's say 5mm bullet holes not be soldered directly to the cells in the lipo in the same way as a "deans lipo"?
Even a hard case lipo with bullet hole conenctors are wired to the cells the same way as a lipo with wires and a Deans connector I would assume.
They are essentially the same. You have two solder joints (esc and cells in the lipo) and a connection. In one case the connection is externally via a Deans plug and in the other case "internally" in the lipo via the bullet holes.
Old 08-11-2015, 06:55 AM   #1469
Skiddins's Avatar
If you look at my post I mention that the Deans packs are wired internally, i.e. I was only talking about prewired packs.
The 4 or 5mm tubes (by the way, every time SMC have tested them, 4mm show lower resistances than the 5mm, strange but true) have to be held in position somehow, this always used to involve the tubes being mounted on a PCB at the end of the pack.
When I first started buying Thunder Power packs (nearly 7 years ago) I spoke to Jim Skinner who asked why UK drivers wanted 4mm tubes on their packs when Dean's packs had lower resistance. He also asked if they would sell more if they were fitted with 4mm tubes and I replied yes. So they started shipping lipo's with the 4mm tubes.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-11-2015, 07:09 AM   #1470
Salkin's Avatar
The 4 or 5mm tubes (by the way, every time SMC have tested them, 4mm show lower resistances than the 5mm, strange but true) have to be held in position somehow, this always used to involve the tubes being mounted on a PCB at the end of the pack..
OK, I see
