Like Tree1Likes
Old 07-27-2015, 08:47 PM   #1441
Trader Rating: 11 (100%+)
Are the belts on the Xray t4 HTD?
cbs007 is offline   Reply With Quote
Old 07-27-2015, 11:09 PM   #1442
Any news about 2016 car?
Dacore is offline   Reply With Quote
Old 07-28-2015, 07:04 PM   #1443
questions the front drive shaft 52mm keep bending. bought new drive shafts and 1 club race and there bent again. driver error mostly! so xray makes ecs shafts are they any better? There about twice as much and they look the same as the regular ones, other than the coupling. are they any more durable.
any suggestions ? anybody running them?
kjsea is offline   Reply With Quote
Old 07-28-2015, 08:09 PM   #1444
erchn's Avatar
Are you running stock spool outdrives, and stock spacing for the lower arm mounts?
Old 07-29-2015, 04:53 PM   #1445
Runing box stock
Old 07-29-2015, 05:14 PM   #1446
erchn's Avatar
Runing box stock
Assuming no other mechanical issue, the X-ray ecs should not bend very easily. I can recommend the Reflex racing dcjs also.
Old 07-29-2015, 05:56 PM   #1447
Thank you
Old 08-01-2015, 12:39 PM   #1448
Could someone let me know the highest number of teeth 48DP pinion gear that fits on the Xray T4?
Old 08-01-2015, 05:08 PM   #1449
KE4PJO's Avatar
that's all spur gear dependent
"If at first you don't succeed, sky diving is not for you" Unknown
"A bad day racing is still better than a good day at work" Me
KE4PJO is offline   Reply With Quote
Old 08-01-2015, 05:23 PM   #1450
I intend to use a 78T spur gear
Old 08-01-2015, 11:02 PM   #1451
erchn's Avatar
https://www.dropbox.com/s/w1kv59lf37xdu2k/xray%20gear%20charts%20table%20%28ratio%201.9%29.p df
Old 08-02-2015, 09:01 PM   #1452
adanmtxt1's Avatar
Adjusted the lower shock mounts to free up the ball joints, then reset preload tweak compensation.
T4 '15 by Lunitic, on Flickr
|Traxxas E-Maxx||Tamiya Super Clod Buster||Team Losi Mini 8ight||Axial SCX10 Wrangler|
adanmtxt1 is offline   Reply With Quote
Old 08-02-2015, 09:55 PM   #1453
vabroom's Avatar
Sorry off the subject:
Do any of you replace the O-rings on the Hudy setup wheels? If so, do you have the dimensions of the o-ring or do you just use the wheel without?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 08-10-2015, 09:45 AM   #1454
Trader Rating: 33 (100%+)
quick question.. what are yalls opinions on battery plugs.. i been using the bullet connectors for my touring car.. i use deans plugs in all other cars.. i popped my ESC this weekend.. cuz the orca batteries are able to be flipped over.. and plugged in backwards.. so.. i was thinking of using plugs to prevent this in the future..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 08-10-2015, 10:42 AM   #1455
KE4PJO's Avatar
Just stay with the bullets, and come up with an "idiot proof" method to place your battery in the car. Like a "this side up" sticker, plug the opposite side holes or something like that..
