Like Tree1Likes
Old 07-19-2015, 06:56 AM   #1426
nexxus's Avatar
R/C Tech Elite Subscriber
Trader Rating: 302 (100%+)
Silly q about DCJ's, I run 21.5 / 13.5 on a wide outdoor flowing track, with a front gear diff are DCJ's going to be any use to me over the stock cvd's? I know for a spool they are worthwhile due to wheel chatter at full lock (learnt that long ago, Tamiya TA05, Front spool, dog bones = BAD!) But in a gear diff is it a worthwhile outlay?
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 07-19-2015, 04:12 PM   #1427
Probably, DCJ are certainly better at large steering angles. Depending on your setup and how you drive ie how much lock you use there will almost certainly be a small benefit whether that is worth the $$$ to you I cant answer.
DamianW is offline   Reply With Quote
Old 07-20-2015, 12:46 PM   #1428
Trader Rating: 113 (100%+)
Today, at my track (a small tight technical track with medium grip, track size is 36x60). I tried the spec r floating servo mount. Best 15 bucks I've spent on an upgrade, that actually made a benefit to my car. This is something I will for sure being using in the future. The floating mount made my car more predictable, and consistent. It gave it a slight amount more steering (as it should). I had to turn my dual rate down 4% to make the equivalent steering as before. I was able to get hot lap after hot lap, and the car just felt great. It also gave the car a slight amount more exit steering.
thecaptain is offline   Reply With Quote
Old 07-20-2015, 06:33 PM   #1429
nexxus's Avatar
How does it differ from the stock standard floating servo mount?
Old 07-20-2015, 06:37 PM   #1430
erchn's Avatar
It's a floating steering rack, not servo, hanging from the graphite servo mount.
Old 07-20-2015, 06:37 PM   #1431
It eliminates the bell crank post that attach to the chassis. It makes the servo mount a floating bell crank mount as well.
Old 07-21-2015, 01:31 AM   #1432
Skiddins's Avatar
The only person I know that has run it used at my local asphalt track and took it off as it killed his corner speed.
Don't know anyone that has tried it on carpet.
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 07-21-2015, 11:17 AM   #1433
Trader Rating: 11 (100%+)
What replacement screws do you recommend ?
cbs007 is offline   Reply With Quote
Old 07-21-2015, 11:24 AM   #1434
R Dodge's Avatar
This feedback on the floating swing rack all sounds correct to me. More flex on the front of the chassis would likely reduce steering on asphalt, but increase steering on carpet.
Or so that's been my experience so far with this car.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 07-25-2015, 09:10 PM   #1435
purple haze's Avatar
xray newb question ..... which concentric bushings will give me no front arm sweep ? do the front mounts have sweep/toe out built in ? thanks .
www.karz.ca
www.carcar.ca
www.rcgears.net
purple haze is offline   Reply With Quote
Old 07-25-2015, 09:11 PM   #1436
erchn's Avatar
Middle dot all around, no sweep by default.
Old 07-25-2015, 11:26 PM   #1437
wtcc's Avatar
Hiro Seiko are of very good quality.
wtcc is offline   Reply With Quote
Old 07-26-2015, 10:16 AM   #1438
chasingthepack's Avatar
moody fools ,very good quality,the screws grip the tool tips very well,never snapped or stripped one and i have them on three cars,lars hoppe is also using them
http://www.moodyfools.com/
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-26-2015, 10:25 AM   #1439
Where are Hiro Seiko screws available in the US?
Old 07-26-2015, 11:13 AM   #1440
Eamotorsports has them.
I have snapped one screw head off of the threads, but I'm putting that to a rare mishap. But I've taken them in and out of my car a lot so they've got the miles on them haha.
