Like Tree1Likes
Old 07-14-2015, 12:30 AM   #1411
daleburr's Avatar
Originally Posted by cbs007 View Post
Please correct me if I'm wrong, the standard driveshafts are 50mm. I'm looking for the shortest driveshafts and I've found CSO driveshafts that are 44mm. Does anyone know of any shorter driveshafts?
Xray measure their driveshaft lengths differently to everyone else. I have a feeling a 50mm Xray is about the same length as a Tamiya/Yok/Etc 44mm
Team Xray
Old 07-15-2015, 05:47 PM   #1412
RocheRCUSA's Avatar
did someone say drive shafts? Radtec 50mm and 52mm DCJ/ECS joints and many many other T4 hop-ups are now available at RocheRC USA
http://shop.rochercusa.com/index.php...ory&path=85_90
2016 ROAR On-Road National Champion 1/12 Modified
North American Distributor for Roche RC and Radtec
http://shop.rochercusa.com / http://www.rochercusa.com
Rapide P12 1/12, Rapide P10 200mm WGT and Rapide F1-16 F1 kits in stock!
RocheRCUSA is offline   Reply With Quote
Old 07-15-2015, 11:24 PM   #1413
Trader Rating: 11 (100%+)
Could someone explain what is the use of a spur gear adapter? Specifically this part http://www.rcracingpro.com/car-parts...so-18093h.html
cbs007 is offline   Reply With Quote
Old 07-16-2015, 02:27 AM   #1414
R Dodge's Avatar
It's just an option part for the central layshaft that holds the spur gear and the 2 center pulleys. It's a little lighter than the stock piece because of the extra holes. Not really a huge gain from it. I have one of them and I had to correct the size of it to fit inside the 5x10 bearing.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 07-16-2015, 03:24 AM   #1415
Skiddins's Avatar
A CSO part that didn't fit correctly
Well that makes a change
#BadlyMadeCrap
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 07-16-2015, 03:36 AM   #1416
rangerjkb's Avatar
Trader Rating: 39 (100%+)
Send a message via MSN to rangerjkb
+1 on other comments. Basically, it is less rotating mass within the drive line to improve acceleration. I imagine it would be difficult to notice the difference in performance between the stock & aftermarket part.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 07-16-2015, 10:51 AM   #1417
Thanks for the advice.
I'm looking for steel/ metal spools and have found this one http://www.rcracingpro.com/car-parts...cso-20213.html
Has anyone used it or know of abou other metal spools?
Old 07-16-2015, 11:14 AM   #1418
locked's Avatar
Would just add to rotating mass and wear down the front belt faster.
I use the spring steel spool outdrives, because the composite outdrives can wear and break a bit too easily, but there's no need for a full metal spool.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 07-16-2015, 11:31 AM   #1419
Would faster rotation of the belts wear the spool?
Old 07-16-2015, 11:39 AM   #1420
Also I'm looking to run thicker belts (4mm-6mm), is there any spool that would allow this?
Old 07-16-2015, 11:41 AM   #1421
erchn's Avatar
Wider or thicker?
If wider, that would be awfully difficult as you'd need a wider layshaft pulley and a wider top deck slot, etc...
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 07-16-2015, 11:45 AM   #1422
Super Moderator
Slo_E4's Avatar
R/C Tech Elite Subscriber
Trader Rating: 58 (100%+)
I've ran the cso aluminum spool. I took it out because it was too rough on the drive clips. Even in 17.5 I would have to change them after a race day. Sometimes one would be completely gone after a heat.
.B.Wilson
Slo_E4 is offline   Reply With Quote
Old 07-16-2015, 11:56 AM   #1423
Sorry, I meant wider spool, wider layshaft pulleys, etc (kinda like a custom car),. I'm wondering whether there are any off the shelf parts or if I have to design and get the parts machined.
Old 07-16-2015, 11:57 AM   #1424
So the aluminium spools are of no use? Mainly trying to use for a speed run car, hence the faster rotation speed.
Old 07-16-2015, 12:44 PM   #1425
locked's Avatar
I have a boosted 4.5 in my mod car. Never had any issues with the composite spool. I've snapped a couple of belts over the years, but they were fairly worn by the time that happened and it was due to high grip acceleration and/or braking. That's not going to be an issue for speed runs.
Dave Locke
