Like Tree1Likes
Old 07-05-2015, 11:17 PM   #1396
alecladanga's Avatar
I agree with what Niznai has said, + 1 on that.
The parts on the xray are very strong and durable as well. Another good point is that xary is very sensitive with its adjustments, meaning that one change here, you'd notice it immediately on the track.
before, it was a great kit for carpet, but this year, it's great for asphalt too!!! 1 & 2 finish at the recent ETS finale
I'm lovin' my T4 '15
Old 07-06-2015, 03:19 PM   #1397
Trader Rating: 13 (100%+)
What final drive for 10.5 Blinky for large-ish asphalt outdoor track 130'x70?
Also what spur/pinion will get me there? 64 pitch.
Thanks for the help.
https://www.gofundme.com/ncontrol
Joe Maxey is offline   Reply With Quote
Old 07-07-2015, 11:16 AM   #1398
CristianTabush's Avatar
Trader Rating: 11 (100%+)
Default New Low CG Carbon Chassis
Hey guys, now available is our new LCG Carbon Chassis:
It is cut from 2.0mm quasi weave, so the flex characteristic is a lot like a stock chassis. The pockets are 0.5mm, therefore lowering your electronics by about 0.75mm over the stock CF Chassis. Another benefit is the motor pocket is nearly not there, so this almost completely equalizes the flex side to side on the car.
We used this chassis on asphalt with a lot of success during the EOS Asphalt season. The car generated lots of grip on our low-medium bite, bumpy asphalt parking lot tracks and maintained good steering throughout. G-Man Herve was able to take down the 17.5 TC title for the 2015 Texas EOS outfitting his car with it.
I also did some testing on our carpet track and honestly, it felt a lot like an aluminum chassis with slightly more response. It certainly decreased traction rolling and made for an easier to drive car over a standard CF Chassis.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is online now   Reply With Quote
Old 07-07-2015, 01:16 PM   #1399
wtcc's Avatar
Nice idea (as always)!
I am running on medium grip asphalt and carpet tracks mostly. Should I go for the 2.0 or 2.25mm version?
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 07-07-2015, 01:48 PM   #1400
It all depends on how much flex you like. The 2.25 might be slightly stiffer than the stock chassis and the 2.0 is pretty close. I like the 2.25 on carpet a lot, and it was fantastic on low bite asphalt, before the grip came up, my car was better than most other cars on the track when I did the testing.
I think the 2.0 with some bulkhead braces might be very close to the settings on the 2.25 as well. So perhaps the 2.0 has a little more versatility. The other advantage of the 2.0 is that it allow to lower the roll center a little bit more.
Old 07-07-2015, 08:20 PM   #1401
Please could you let me know the lowest teeth spur gear that works on the Xray T4 without any modification.
cbs007 is offline   Reply With Quote
Old 07-07-2015, 08:47 PM   #1402
I still use this as my reference for FDR and spur/pinion combo for the T4 '15.
This isn't mine but got it from another Xray thread here, T3 2012.
64pitch
Old 07-07-2015, 09:37 PM   #1403
I did see that pdf, but the lowest Xray Spur I can find is 78T( 64 pitch). I'm wondering if any aftermarket manufacturers make Spurs with lower number of teeth?
Old 07-11-2015, 09:46 PM   #1404
adanmtxt1's Avatar
Are the pivot balls in the lower shock mounts supposed to be free like the upper pivot ball mounts, or stiff? My upper balls move with that 'engineered-in play' but there is no free movement in the lower ones. Everything else on my car is perfect, aligned, and running beautifully.
|Traxxas E-Maxx||Tamiya Super Clod Buster||Team Losi Mini 8ight||Axial SCX10 Wrangler|
adanmtxt1 is offline   Reply With Quote
Old 07-11-2015, 10:17 PM   #1405
Yes they should be free, you may have screwed the plastic ball cup too deeply on to the end of the shock shaft which can make the ball tight in the cup.
DamianW is offline   Reply With Quote
Old 07-12-2015, 02:30 AM   #1406
Barry_Hughes's Avatar
Yes lots, I use RW spurs with the XRay Offset, if you search this thread this question gets asked a lot I believe others are Panaracer and I can't remember the others without searching the thread
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 07-12-2015, 08:39 PM   #1407
adanmtxt1's Avatar
and since I've been pestering you all so, I thought I'd share a few pics I took today. I've been running HPI Super Radial tires until today which have less overall grip but break and slide more predictably and smoothly on the unprepared pavement I run on most often. These Sorex slicks are nice though so far.
And the Hitec servo wire bundle looks messy in this pic but it's actually neatly coiled in a loop and zip-tied in a stack above the servo attached to the top deck. Everything is really neat.
DSC_4018m by Lunitic, on Flickr
DSC_4021m by Lunitic, on Flickr
DSC_4023m by Lunitic, on Flickr
DSC_4026m by Lunitic, on Flickr
Old 07-12-2015, 08:44 PM   #1408
Love the rims and body, looks awesome.
Old 07-13-2015, 10:49 PM   #1409
Please correct me if I'm wrong, the standard driveshafts are 50mm. I'm looking for the shortest driveshafts and I've found CSO driveshafts that are 44mm. Does anyone know of any shorter driveshafts?
Old 07-13-2015, 10:55 PM   #1410
the front is 52MM and the rear is 50MM.
if you will be using 44MM driveshafts, they are designed for the front and you would also need to buy aftermarket spoolcups for the 44MM to fit.
