Like Tree1Likes
Old 06-23-2015, 08:57 AM   #1381
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by SpidarX View Post
Link doesn't work for me.
tested this link is ok ,
http://rcmarket.com.hk/index.php?cPa...sort=3a&page=2
or
http://rcmarket.com.hk/index.php?cPath=51_98_117_375
Old 06-23-2015, 09:13 PM   #1382
adanmtxt1's Avatar
Could someone recommend a starting place on a pinion gear for general fun-running with an X20 13.5 stock motor? A new kit will arrive for the weekend for me but I'm not sure where to start with gearing.
|Traxxas E-Maxx||Tamiya Super Clod Buster||Team Losi Mini 8ight||Axial SCX10 Wrangler|
adanmtxt1 is offline   Reply With Quote
Old 06-23-2015, 10:36 PM   #1383
wtcc's Avatar
We decided for a gearing of 5.0 at our club for blinky. With this you do not risk the motor at all. Temperatures stay low, the car is fast and if you want more speed you can start from there.
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 06-24-2015, 04:38 AM   #1384
adanmtxt1's Avatar
Excellent, thanks buddy. Will start there and see how she runs. Not sure if I'm looking forward more to the build and setup or running .
Old 06-24-2015, 04:39 PM   #1385
The X20 is happier at closer to 4 than 5. It's a torque motor, not a revver.
I ran mine at 3.9 (large track) with the 37.5 timing insert and it used to come off at a good temp (around 70degC).
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 06-24-2015, 11:18 PM   #1386
alecladanga's Avatar
I agree, for a torque motor, best to have a lower FDR.
For TITC 2015, blinky hand out motor was a Bandit HW (torque motor) and we ran it with 3.1 FDR, 35 motor timing (open and large track) and the motor temp was okay.
for boosted 13.5T, same motor, FDR was around 4.3 - 4.7
We had a minimum of 2 fans on the motor though.
Just as a point of comparison.
Old 06-24-2015, 11:56 PM   #1387
wtcc's Avatar
Just keep in mind that X20 is running hotter than many motors. If outside temps are around 25-30 *C and asphalt 40-50 *C it is easy to reach unhealthy temps in the motor.
I am running on a small/medium ashalt track . He asked for a safe setup not one where you need two fans to stay competitive with the worlds best drivers...
Old 06-25-2015, 05:07 AM   #1388
adanmtxt1's Avatar
When you all are quoting ratios, FDR is the final drive taking into account the full internal drivetrain ratio (layshaft pulley to diff gear as well), not simply the primary pinion to spur ratio, correct? Just want to be sure I'm on the same page here.
Old 06-25-2015, 08:12 AM   #1389
Trader Rating: 33 (100%+)
yes.. that is correct. there is an app out there for phones.. that has the Xray T4 FDR calculation.. its called rc final gear ratio. it calculates it for you. just type in spur and pinon numbers.. and calculate.
i did not create the app.. i just use it.
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 06-25-2015, 06:13 PM   #1390
Old 07-02-2015, 11:18 AM   #1391
Chris Adams's Avatar
Hey guys,
Just got back from Gulf Coast raceway down in Porter where they held nitro sedan worlds at. I ended up using the PSS shock system down there and thought my car developed more traction than all the other xray cars.
https://www.facebook.com/TexasEos?re...homepage_panel
Video is near the top of the page.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is offline   Reply With Quote
Old 07-04-2015, 10:19 PM   #1392
purple haze's Avatar
hey guys , when does xray usually release their new kits ? sept ?
www.karz.ca
www.carcar.ca
www.rcgears.net
purple haze is offline   Reply With Quote
Old 07-04-2015, 10:59 PM   #1393
pcar951's Avatar
Trader Rating: 19 (100%+)
Usually November or December. Thinking of making a change, a main?
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 07-05-2015, 10:05 PM   #1394
I was thinking about trying something new .... just not sure what flavour .
www.karz.ca
www.carcar.ca
www.rcgears.net
Old 07-05-2015, 11:10 PM   #1395
niznai's Avatar
Go Xray. Right now it's probably the most advanced in features and adjustability. I foresee most will try to catch up with their future releases (which makes youwonder what will Xray do next). Right now I think the sway bar setup is the nicest on Xrays and for once you can adjust it with minimal fuss. The rest look like afterthoughts.
Personally I have my eyes both on the next Xray and the TRF. If they're both good, I might get both.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
