Like Tree1Likes
Old 06-21-2015, 05:16 PM   #1366
Originally Posted by DamianW View Post
Xray white low friction belts are good. but $$$
The kit yokomo bd7 belts are awesome and very cheap.
I heard the white low friction ones don't last that long. Or is that false information?
Yokomo belts are 516 and Xray 513 teeth. Since I run my belts quite tight (mod), 516 might be too much (?)
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 06-21-2015, 05:33 PM   #1367
I still have the kit xray front belt, and I cant get it loose enough but I use the kit yokomo belt in the rear.
The white low friction belts are manufactured differently not only are they lower friction but they are also stronger.
Perhaps try less belt tension, the looser they are the longer they last provided they don't skip.
DamianW is offline   Reply With Quote
Old 06-21-2015, 05:55 PM   #1368
Tnx for the input.
I already use Yokomo rear belt. I heard the oppsite about the white belt, but I might give it a try.
My belts are certainly not too tight, especially for mod. Have been racing mod for many years now, so tension is not a problem. I know when my belt will skip. And it will if it's too loose.
Are there no other brands available that make rubber belts? I have been searching a lot, but I can't imagine...
Modified 4 life
Old 06-21-2015, 06:13 PM   #1369
Pretty much all the cars use belts manufactured by Bando.
They have a few different belts with the same teeth profile with slightly different properties rubber and re enforcing.
Spec R, 3 Racing, Xray and Yokomo are bando belts.
The white xray belts are the same belt as the yoko white belts and I can assure you the yoko belts last.
Old 06-21-2015, 06:21 PM   #1370
Skiddins's Avatar
Originally Posted by Skiddins View Post
Don't think they will fit, but didn't occur to me to see if they would.
Ran them on carpet last night, back to back checking, PSS with 500cSt against 4x1.1 with 400cSt.
Couldn't honestly feel any difference between them.
I did two runs with each (proper rounds of quali) swapping back and forth and my fastest laps were separated by 3 hundreths across the runs!
Perhaps they work better on more flowing track, ours tends to have some tight 180's etc, and running boost we tend to brake late and try and throw the cars in.
Asphalt testing at my local track on Sunday
Skiddins
Ran the PSS shocks at my asphalt track today and I do think they helped a little with consistency (same oils etc as indoors)
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 06-21-2015, 07:14 PM   #1371
Hagberg ran them at AOC on the weekend and said he likes them alot.
don't expect them to be included in the '16 model though
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 06-21-2015, 07:56 PM   #1372
Trader Rating: 25 (100%+)
Belts break when they are too tight. Try the kit settings if you are breaking a lot of belts.
Sir Loin is offline   Reply With Quote
Old 06-22-2015, 03:10 AM   #1373
My t4 15 ran so good sat on high bite carpet in blinky 21.5 class.it was 1 lap slower than 13.5t class.i ran ars for the first time. Without rear swaybar schumacher rallyblock blues on front and blue schumacher minipins on rear.
thomasd is offline   Reply With Quote
Old 06-22-2015, 04:03 AM   #1374
Geberit's Avatar
http://forum.teamxray.com/xform/inde...&setup=t4_2015
Rear ARB 1,5mm? Is thir right? This is something new
Geberit is offline   Reply With Quote
Old 06-22-2015, 04:57 AM   #1375
Thanks, but certainly not too tight or not too loose. They just wear out (not breaking) because I race on a large open track, which stresses out the belt alot under accelerating and braking. I'm not a novice in this hobby.
I owned a Capricorn EP, which came with rubber (coated) belts and they lasted way longer. Now I'm trying to find the same for my Xray..
Modified 4 life
Old 06-22-2015, 07:28 AM   #1376
Chris Adams's Avatar
Thanks, but certainly not too tight or not too loose. They just wear out (not breaking) because I race on a large open track, which stressed out the belt alot under accelerating and braking. I'm not a novice in this hobby.
Spec -R makes an incredible rear belt. Seems like it has more rubber on it. Its what I use now for large tracks.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is offline   Reply With Quote
Old 06-22-2015, 09:03 AM   #1377
CristianTabush's Avatar
Trader Rating: 11 (100%+)
Yes, the belt Chris refers to is the Spec R R1/R2 belt. Not the Spec R Low friction belt, which wears quick. The belt for the R2/R1 is also only like $3.50 and on large tracks, it's the only way to go.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 06-22-2015, 05:33 PM   #1378
Thanks guys. Will take a look at that.
Modified 4 life
Old 06-23-2015, 03:37 AM   #1379
RC MARKET's Avatar
Trader Rating: 12 (100%+)
TOP same had low friction belt same XRAY with bester price
http://rcmarket.com.hk/index.php?cPa...sort=3a&page=2
Old 06-23-2015, 08:15 AM   #1380
SpidarX's Avatar
Link doesn't work for me.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
