Like Tree1Likes
Old 06-17-2015, 07:08 AM   #1336
Default T4 driveshaft
Hello i am New to touring and bought t4 2015 and tried IT for the first tim yeasterday.. Loved it ! But i bendt the front driveshaft.. My father have the same car,and he has 2 spare rear driveshafts 50mm.. They seem to fit..is there any reason i should not use the rear alu driveshaft in front?the front are steel, But very fragile it seems..the rear ones seems beefy..any input is Great! Sorry for my bad english..
magstaff is offline   Reply With Quote
Old 06-17-2015, 07:53 AM   #1337
Chris Adams's Avatar
The rear shafts will bend much more easily that the front. Replace the stock front cvd's with a set of ecs's. Xray has the ones that I have been using but companies like rsd have great options as well and they are less expensive.
Chris Adams is offline   Reply With Quote
Old 06-17-2015, 08:00 AM   #1338
RC MARKET's Avatar
Trader Rating: 12 (100%+)
XRAY New RSS
Old 06-17-2015, 08:01 AM   #1339
Salkin's Avatar
Originally Posted by Skiddins View Post
They said that they found that the harder oils seemed to improve traction (but this was on asphalt), it's also before they announced they had been using the PSS system.
I have a feeling that at full extension the damping they offer is too soft with the normal oils
Yes, we will try the 550 oil to see the difference.
In Luxembourg Hagberg/Coelho used 550 oil, and I was not aware at that time that they were using PSS.
400/450 worked better for us in Luxembourg, using "normal" dampers.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 06-17-2015, 08:21 AM   #1340
thank you for fast reply! is the rsd ecs`s a direct fit ore do i need anything else?
Old 06-17-2015, 08:51 AM   #1341
metalnut's Avatar
R/C Tech Elite Subscriber
Trader Rating: 36 (100%+)
The RSD ECS for the T4 are a direct fit, but they use a 3mm inner hub bearing (and come with the bearings). I use them and they work well.
You can also use Tamiya DCJs, but those require different outdrive cups.
- Ricky Bobby
Old 06-17-2015, 10:16 AM   #1342
I used the PSS this last weekend on a bumpy large asphalt track. On a hot track, you will most likely need to go even heavier than 550. I ended up going back to the standard shock as I felt more comfortable with them. Next time out I will have 700 weight oil in the PSS and see if that is good enough for the Texas heat.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Old 06-17-2015, 10:31 AM   #1343
Trader Rating: 125 (100%+)
What do you feel the pss did?
thecaptain is online now   Reply With Quote
Old 06-17-2015, 11:25 AM   #1344
chiefj48's Avatar
Please correct me if I'm wrong.
I thought I read the best part about the pss is you don't have to change the shock oil and that they self adjust as they travel.
I thought they were to eliminate the shock oil worries so you can focus on the suspension?
chiefj48
Home of the; 2016 ROAR On Road Paved Nationals
Special Thanks, RocheUSA, SerpentUSA, AwesomatixUSA, ValkariaRC, Trinity, DiscountRCStore, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 06-17-2015, 12:04 PM   #1345
RC MARKET's Avatar
XRAY New Alum. Shim
Old 06-17-2015, 02:23 PM   #1346
Skiddins's Avatar
You're still going to have to find the right oil for the situation.
I certainly didn't think they were going to be aq miracle cure for suspension woes.
I now have some and will be testing on carpet and then on asphalt at the weekend.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 06-17-2015, 02:34 PM   #1347
wtcc's Avatar
Nice, I am waiting for your experience.
I haven't seen this option part on any teamdriver setup so far, so I am a little sceptical about a performance advantage...
/// CAUTION: Rogue robot \\\
wtcc is offline   Reply With Quote
Old 06-17-2015, 03:18 PM   #1348
I'm almost positive Alex and the rest of the team have been using them at almost every race. They had them at Worlds last year and our car was really good.
Old 06-17-2015, 03:21 PM   #1349
No, like skidding said, the oil will change. I imagine 550 oil would work on a very smooth surface that is not very hot. Here in the states 550 is prob too light as it will thin out with the heat.
Old 06-18-2015, 12:50 AM   #1350
Salkin's Avatar
If you go to the setup section on teamxray.com you can see that most of the latest team driver setup sheets specify the use of either progressive shocks or PSS in either the "Shock" section in the setup sheet or in the comment field at the bottom.
http://forum.teamxray.com/xform/inde...&setup=t4_2015
