Like Tree1Likes
Old 05-17-2015, 01:05 PM   #1216
artwork's Avatar
Trader Rating: 59 (100%+)
Originally Posted by kobiwan View Post
I'm currently building a T4 '15 and just completed putting on the rear a-arms and they don't move freely. I have diagnosed that it is the inserts. when i put the hinge pin the the insert they don't rotate freely inside. Anyone have a fix for this? Thanks
The hinge pin is not supposed to be free inside the insert. The arm has to be reamed so that it spins around the hinge pin. Use a 3mm arm reamer to fix this.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 05-17-2015, 02:33 PM   #1217
Use a reamer the susp. arms are supposed to turn over the hinge pin.
Do this with all arms and check the smoothness while rotating over the hing pins.
eded1 is offline   Reply With Quote
Old 05-17-2015, 02:41 PM   #1218
Sanwa M12S---Xray T4 '17 ---Team Scream---Promatch---Hobbywing
kobiwan is offline   Reply With Quote
Old 05-17-2015, 02:42 PM   #1219
Also, Should I get the aluminum Steering bellcranks, or are the plastic ones okay to use?
Old 05-17-2015, 06:47 PM   #1220
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I prefer the extra throw the aluminum arms afford, but they are prone to allowing the two ball studs loose. To get the extra throw and not lose the ball studs I know use the plastic arms and use the RSD narrow center shim which gives approximately the same mount of throw.
"Whether you think you can, or think you can't, you're right." -Henry Ford
"[Driving] Genius is 1% inspiration, and 99% perspiration" -T.A. Edison
|◤Hobbywing◢|◤SpeedzoneUSA.com◢|◤Pro-One◢|
|◤ReflexRacing.net◢|◤Protoform◢|◤AVID R/C◢|
andrewdoherty is offline   Reply With Quote
Old 05-17-2015, 07:01 PM   #1221
erchn's Avatar
You really shouldn't need to use a reamer on the arms, if the pin spins freely in an u mounted arm. Mount it all up as square as you can and give the arm a good whack or two with a nut driver. It'll align the blocks and things should move freely.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
Old 05-17-2015, 11:21 PM   #1222
Trader Rating: 11 (100%+)
I'm new to belt driven TC and am sorry if this is trivial.
Do the Xray T4 '13/14/15 come with spools in the front and rear? If not could someone let me know whether there are optional parts to convert the front and rear to spools.
cbs007 is offline   Reply With Quote
Old 05-17-2015, 11:55 PM   #1223
Salkin's Avatar
The manual directly specifies to use a reamer.
The arm must move freely on the pin (as does the uprights/c-hubs), it is NOT the pin that should move freely in the plastic hinge pin holders.
I would definitely NOT give anything a whack or two with a screwdriver to get it to operate smoothly.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 05-18-2015, 12:57 AM   #1224
TryHard's Avatar
Might want to watch this video to see what Erchn means....
https://www.youtube.com/watch?v=zAPI...4179DA&index=3
go to 6:00min.
| THard.co.uk | Xray | Hobbywing |
TryHard is offline   Reply With Quote
Old 05-18-2015, 01:52 AM   #1225
Skiddins's Avatar
The last few generations of Xray kits come with a spool in the front and a gear diff in the rear.
They are the same fitment though, so if you download the exploded diagram of the car you want, from Xray, it will tell you the part number of any parts you might want.
http://www.teamxray.com/t4/
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 05-18-2015, 02:22 AM   #1226
R/C Tech Elite Subscriber
Trader Rating: 55 (100%+)
go to 6:00min.
I was thinking I saw this also. Hammer might be too much lol. But a little tap to get it to settle seams harmless.
Jamison R is offline   Reply With Quote
Old 05-18-2015, 04:53 AM   #1227
Salkin's Avatar
go to 6:00min.
Well, the Tamiya has these small alu balls that slide onto the end of the pins and the pin can move (rotate) freely in the "ball". What Gilles demonstrates is only applicable to that and have no direct relevance for an Xray which does not use these alu end balls.
I've had Tamiya before Xray and have watched all of Gilles very good demonstration videos, but some of the info is only applicable for Tamiya TRF cars and are not universal.
Please correct me if I'm missing something
Old 05-18-2015, 05:00 AM   #1228
Salkin's Avatar
+1
....like the manual instructs.
Old 05-18-2015, 05:46 AM   #1229
I am trying to re-order some Xray shock oil. 350, 400, and 450 CST. I usually order from Stormer, Amain, Superior, or TQrcracing. Nobody has it. As in they don't carry it, its not that it's out of stock. Stormer has a few bottles left but not the thickness I need. Anyone know where I can get some?
Old 05-18-2015, 07:23 AM   #1230
erchn's Avatar
I'm pretty sure xray oil is being discontinued. The Hudy oil is the same high quality stuff, and cheaper if I remember correctly.
