Like Tree1Likes
Old 05-05-2015, 07:32 PM   #1186
erchn's Avatar
Originally Posted by artwork View Post
He also had is steering rack upside down and his c-hubs on backwards...that dude is simply a great wheel.
Wrong race, but yea, he's a wheel.
Old 05-05-2015, 08:22 PM   #1187
I think ARS might be good outside but on med/high bite carpet it does not work.
Any ideas why ARS doesn't work on carpet?
DamianW is online now   Reply With Quote
Old 05-05-2015, 11:00 PM   #1188
pcar951's Avatar
Trader Rating: 19 (100%+)
I tested with ARS for a month last carpet season. I found that although it gave me more adjustment to tailor the feel of the car, it didn't improve lap times. For me, adding tow mid corner was most effective on our typically low grip carpet tracks here. Never had the chance to test on high grip. if I ran on low grip asphalt I'd certainly try ARS again. JMO
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 05-06-2015, 04:58 AM   #1189
This is just my thoughts I havent tested it or anything and I have 0 carpet experience but it makes sense.
The main goal of the ARS is to give more mid corner grip for the rear. More grip=more power or earlier on the power.
On high grip carpet tracks you dont need more grip mid corner. It will only cause unnecessary friction by giving more rear toe in.
On a outdoor track or low traction track you need the grip thus it would be more effective.
777Yoda777 is offline   Reply With Quote
Old 05-06-2015, 05:30 AM   #1190
Skiddins's Avatar
That was definitely the worlds, in practice his C hubs were incorrect and the steering arms upside down.
The C hubs were put correct. but in the end he preffered the rack upside down so left it lol.
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-06-2015, 11:46 AM   #1191
Skiddins
Hi Skiddins.
What ever Coelho did it seems to me he understand the way ARS works.
On a low grip track the ARS can give you mid corner grip.
On a high bite track with the ARS angled from mid high to the steering blocks low it give the rear a bit of steering and the car is less pushing, result in more corner speed and on throttle more bite thanks to lower front tyre temp.
Try to imagine what the geometry do.
I can not guarantee that you always getting better lap times but this is how it works.
eded1 is offline   Reply With Quote
Old 05-06-2015, 03:52 PM   #1192
So do you want ARS to increase toe in under compression or reduce it?
Old 05-06-2015, 05:12 PM   #1193
Skiddins's Avatar
Depends on driving style, some like it to add toe, some reduce it, so you'll need to experiment.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-06-2015, 05:26 PM   #1194
Skiddins's Avatar
Originally Posted by eded1 View Post
Hi Skiddins.
I understand what the geometry does with the ARS settings, but there are no hard and fast rules as to when it will make the car faster, or feel better.
For example, Hagberg's starting setup for Austrian ETS had ARS, but they took it off when it became apparent that the grip was strange and too low.
It really is something that you'll just have to test at each track to see if it works.
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 05-06-2015, 05:57 PM   #1195
R Dodge's Avatar
ARS also requires consistent driving. If you drive 3' deeper into a corner than you did the lap before, it's gonna feel different that lap. This may explain why most seem to prefer the traditional rear suspension.
I'm sure there are instances where ARS is the clear choice. Just seems a little harder to figure that out
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is online now   Reply With Quote
Old 05-11-2015, 12:51 AM   #1196
Salkin's Avatar
I know the short answer is try it and see if it works....
...but have anyone experience with the alu chassis on outdoor asphalt tracks (mod)?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 05-11-2015, 12:28 PM   #1197
I agree by what you are saying, it differ for everyone.
Old 05-11-2015, 10:27 PM   #1198
CristianTabush's Avatar
Trader Rating: 11 (100%+)
Default RX4-15 Aluminum
Hi Guys, I know it's not the carpet season, but we've had some good luck running with this chassis even on asphalt.
This chassis is the culmination of 6 months of hard work and testing at our carpet facility. It was the first aluminum chassis project we cut on our cnc router and also the one we spent the most hours on trying different cut outs, flute size and depth, motor pocket width, and different chassis shape.
The chassis initially started life with the RX4 V2 chassis shape and as the project carried on, the shape and features evolved to what we present to you today. The RX4-15 is a labor of love and persistence. Every effort was made to give you the most balanced, versatile chassis for your T4 that is capable of being run with the stock top deck under most conditions.
The result is something we are really proud of. More steering, traction and easier to drive is the most common feedback we get- and we totally agree.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-12-2015, 01:09 AM   #1199
chasingthepack's Avatar
with all the talk about raising the top deck 0.5mm you would think a clever chap like Christan would have develop a shim strip with a tab on the side to hold it while you pop the screws back in,fiddling around with tiny single shims is a pain,how long till we see them in the stores
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 05-12-2015, 01:24 AM   #1200
daleburr's Avatar
Yes please, I'd buy some! 0.5mm carbon shims would be spot on.
Team Xray
