Like Tree1Likes
Old 04-11-2015, 05:09 AM   #1141
Skiddins's Avatar
Originally Posted by Barry_Hughes View Post
I built my car with ARS and tried many setups.
The problem I found was the car always felt tail happy and I wasn't confident in really pushing with it on.
The best set up was adding 4mm shims to the inside chassis mount and mounting the outside ball stud on top of the arm rather than below. Set static rear toe to 1 degree in. With this the rear was more planted and I felt more confident with the car. With this set up I could get a quicker single lap time, but the car was still inconsistent, a problem I found using the ARS.
I have changed back to the standard rear set up (non ARS) and found I have a lot more confidence in the car and lap times are more consistent and therefore the overall race run is quicker, even if the single best lap is fractionally slower
Did you add shims at the wheel to allow for the fact that the ARS reduces the track width by quite a lot, seem to recall it's 1mm each side!
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-11-2015, 01:19 PM   #1142
Dusttt's Avatar
Trader Rating: 123 (100%+)
Anyone try the avid aluminum chassis on asphalt?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Old 04-11-2015, 02:40 PM   #1143
Barry_Hughes's Avatar
yep tried that as well, forgot to add that one , was still best with with ball studs on top + 1mm shims
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 04-21-2015, 07:44 PM   #1144
hello
i just purchased a t4 15. am planning running 17.5 class. am wondering what spur gear and pinion gears i need. the track is asphalt 140 x 60. am planing on running 64p gears. any help would be great am new to on road.
kjsea is offline   Reply With Quote
Old 04-21-2015, 08:51 PM   #1145
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
Originally Posted by kjsea View Post
hello
Many guys use a 96T spur, but depends on each persons preferences. Several 17.5 motors work well geared between 3.6-4.0 Final Drive Ratio (FDR) range. If your larger track has an open layout, I'd recommend starting at around 3.6'ish FDR. A 45T through 50T pinions would cover the gearing range for fine tuning to suit different track layouts/needs. Hope this is helpful and have fun at the track!
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 04-21-2015, 08:58 PM   #1146
mschumi101's Avatar
Trader Rating: 21 (100%+)
hello
See what the guys are running locally as far as their FDR goes and if they are running a fan or not. My guess would be anywhere from a 3.2-3.6 FDR. I usually like to run a 92t 64p gear for 17.5, and occasionally a 96t spur gear. Anything larger is rarely used in stock, and smaller gears tend to have troubles with the motors contacting the top deck. As for pinions I would get a range of about 48t-55t. That way you can be prepared to run whatever FDR the local guys use, and then adjust slightly for your specific motor.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is online now   Reply With Quote
Old 04-21-2015, 09:02 PM   #1147
rangerjkb's Avatar
A fellow racer used the Avid '14 Graphite Chassis last weekend with exceptional results (also used Avid shock towers and thin upper deck). Working to modify an Avid graphite chassis to fit a '15. Have had very positive results using the Avid shock towers and thin upper deck on stock Xray chassis.
Jason Burks
Old 04-22-2015, 01:49 PM   #1148
First race day at indoors running 21.5 blinky class on carpet and I won by 2 laps.
I still have minor changes to make.
What a great car.
thomasd is offline   Reply With Quote
Old 04-22-2015, 05:38 PM   #1149
thanks you for your help
Old 04-22-2015, 08:25 PM   #1150
what kind of lipos are you guys running mah and c ratings ? brands?
Old 04-22-2015, 08:50 PM   #1151
rangerjkb's Avatar
Recommend Mid-6000 mAh's or higher (hardcase battery/ROAR approved) with a high 'C' rating for stock applications. Most all of the manufactured labeled batteries perform very well. Example, but not limited to: Team Powers Racing, Murfdogg, Orion, Trinity Revtech, ProTek, SMC, Psycho Cell Racing, Intellect, Reedy, etc...
Jason Burks
Old 04-23-2015, 02:34 AM   #1152
Skiddins's Avatar
If you buy Revtech, check that it has roughly the capacity stated on the pack, I had problems with their 1s packs.
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 04-23-2015, 03:20 AM   #1153
Lrp 7000 110/c burst
Old 04-23-2015, 04:52 AM   #1154
Salkin's Avatar
Orca and Much More lipo's.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 04-23-2015, 05:32 AM   #1155
R/C Tech Elite Subscriber
Trader Rating: 55 (100%+)
Any of the IP based packs. With 7000 and up mah 90-100c
http://m.ebay.com/itm/like/171622918...d=819294334392
These are the same as orca etc.
Jamison R is offline   Reply With Quote
