Like Tree1Likes
Old 04-06-2015, 04:01 PM   #1126
Chris Adams's Avatar
Originally Posted by SpidarX View Post
I am having a problem with stripping spur gears on my T4 '15. Even though I tighten down the motor mounting screws...it is slipping. Any suggestions?
At Al's, its probably track debris causing it. If not, you may have the mesh a little too loose. With 64 pitch, it has to be perfect gear mesh, especially now with the stronger motors. I suggest going to 48 pitch if it continues once the mesh is set perfectly.
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs
Texas EOS 2017!
Chris Adams is offline   Reply With Quote
Old 04-07-2015, 12:58 AM   #1127
daleburr's Avatar
Clean the motor and motor mount with brake cleaner to make sure there's no grease/oil on the surfaces.
Make sure the screws are as long as you can possibly use without them fouling on the motor internals. Then tighten the screws down really tight.
And as suggested, use 48dp. This will allow a small amount of movement in a big crash without stripping the gears.
Team Xray
Old 04-07-2015, 06:52 AM   #1128
SpidarX's Avatar
Thanks guys for the suggestions. Now that I think about it, I had a diff leak a few weeks ago, perhaps the oil is on the mount causing the motor to not stay secure. I will definitely clean things thoroughly.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 04-07-2015, 07:02 AM   #1129
niznai's Avatar
Are you using some spring washers on those motor screws?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 04-07-2015, 09:08 AM   #1130
SpidarX's Avatar
No
Maclan Racing
Old 04-07-2015, 09:24 AM   #1131
erchn's Avatar
No
They wouldn't help either.
Old 04-07-2015, 09:49 AM   #1132
Salkin's Avatar
I have never had any problems with the motor not staying tightly in place. I don't even think a little oil would cause any trouble.
Are you sure the edge of your motor does not rub on the upper deck so it can not be tightened fully. Some motors either do not have a beveled edge or one of the motor screws in front rubs on the top deck, which can be solved by rotating the motor some degrees to the next mounting holes.
This issue is also described in the manual.
You are not using too long screws to secure the motor, in the motor mount, so they tighten against motor internals instead of the motor mount?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 04-08-2015, 02:20 PM   #1133
SpidarX's Avatar
Is there any difference between a regular panaracer spur and a yokomo branded panaracer spur?
For instance, will the following work for the xray?
http://www.amain.com/rc-cars/yokomo-...7-6496/p242268
Maclan Racing
Old 04-08-2015, 02:25 PM   #1134
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
same thing, they'll work.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 04-10-2015, 11:40 AM   #1135
Has anyone got a good carpet ars setup
thomasd is offline   Reply With Quote
Old 04-10-2015, 01:09 PM   #1136
Build your ARS on your car and set-up as close to your normal set-up.
Than you can play with your ARS rod to set it higher or lower.
The rest is your feeling and ability to handle your car.
For my self I have build the car and have only driven with ARS and it is good.
Good Luck.
Ed
eded1 is offline   Reply With Quote
Old 04-10-2015, 08:32 PM   #1137
SpidarX's Avatar
Well, I found my problem. I thought I would post so maybe someone else doesn't make the same mistake. The stripping problem was caused by the button head screw that goes on the bottom of the chassis into the motor mount. It came loose and was allowing flex in the mount which was allowing the play between the spur and pinion.
Maclan Racing
Old 04-11-2015, 12:25 AM   #1138
Danny-b23's Avatar
I personally don't really like the ARS on carpet. The stock rear end has been better for me.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 04-11-2015, 01:32 AM   #1139
Barry_Hughes's Avatar
Good Luck.
Ed
I built my car with ARS and tried many setups.
The problem I found was the car always felt tail happy and I wasn't confident in really pushing with it on.
The best set up was adding 4mm shims to the inside chassis mount and mounting the outside ball stud on top of the arm rather than below. Set static rear toe to 1 degree in. With this the rear was more planted and I felt more confident with the car. With this set up I could get a quicker single lap time, but the car was still inconsistent, a problem I found using the ARS.
I have changed back to the standard rear set up (non ARS) and found I have a lot more confidence in the car and lap times are more consistent and therefore the overall race run is quicker, even if the single best lap is fractionally slower
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 04-11-2015, 01:57 AM   #1140
niznai's Avatar
They're an extra layer of backup safety. Personally never had a motor come loose, but then again, always used spring washers. Nothing more annoying than a DNF because of lost mesh. And I have to say, my car has done some spectacular aerobatics (sic) at times.
Team Greasy Weasel
