Like Tree1Likes
Old 03-18-2015, 01:09 PM   #1096
Salkin's Avatar
Originally Posted by eded1 View Post
Try Arena out drives, very good steel no blades, cups have 4 sleeves.
Dont forget to put some grease f.e. tamiya heavy duty grease.
I use them for mod 4.5 on a very demanding track and they do well.
Thanks for the info
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 03-18-2015, 05:30 PM   #1097
Tech Prophet
Trader Rating: 1069 (100%+)
Is there a toe matrix some where for the suspension eccentric bushings?
Also are the ball bearing roll bars just shorter than the T4?
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 03-18-2015, 05:59 PM   #1098
Sal Amato's Avatar
R/C Tech Charter Subscriber
Trader Rating: 26 (100%+)
[QUOTE=bigwavedave33;13912904]Is there a toe matrix some where for the suspension eccentric bushings?
I was just thinking about this today, wish there was..
360 RC SPEEDWAY 2.0
AWESOMATIX USA-SANWA--BSR--TEAM SCREAM --SWEEP RACING USA--TQ WIRE--ROCHE USA--LRP
Sal Amato is offline   Reply With Quote
Old 03-18-2015, 09:07 PM   #1099
Trader Rating: 22 (100%+)
i googled this and cant seem to find it.
link?
Bob
goneracin is offline   Reply With Quote
Old 03-18-2015, 09:30 PM   #1100
Trader Rating: 23 (100%+)
+1
Is there someone here who is able to enlighten us on what changing the bushings allows us to do?
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 03-18-2015, 09:51 PM   #1101
vabroom's Avatar
link?
Bob
He probably means these:
http://rcmarket.com.hk/product_info....ducts_id=13782
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is online now   Reply With Quote
Old 03-19-2015, 12:35 AM   #1102
Salkin's Avatar
For the steel outdrives I have also found these:
http://www.fast-webshop.com/tonispor...xle-Drive-Cups
http://www.fast-webshop.com/tonispor...ing-Steel-2pcs
http://www.fast-webshop.com/tonispor...-S1-Xray-T3-T4
Old 03-19-2015, 02:02 AM   #1103
daleburr's Avatar
Not that I've seen. But it's pretty simple; if you have the same inserts on both sides of the arm (RF and RR) you'll have 3deg toe. Any change of insert just adds or removes toe in 0.5 or 1.0 deg increments.
No they're a different shape as well, they're wider across the bulkheads to make room for the orange insert/holders.
Team Xray
Old 03-19-2015, 02:44 AM   #1104
Salkin's Avatar
About the 0.5/1 degree increments in toe, I have seen several Alexander Hagberg setup sheets where he specifies an "uneven" toe number, e.g. 2.7. See this setup sheet:
http://forum.teamxray.com/xform/inde...&setup=t4_2015
How is that possible?
Old 03-19-2015, 05:29 AM   #1105
daleburr's Avatar
A couple of possibilities. As a factory driver he might have an optional RR alloy block that adds or removes 0.25deg toe to allow 'in between' settings.
Or more likely, he is quoting the value reported via a setup system, rather than the nominal value. My T4 '14 and '15 both show 3.2deg toe on my Hudy setup station with kit inserts, so I would also have 2.7 (measured) if I ran the inserts that Alex was running in that setup.
It never used to matter very much, but if you ever use ARS (as Alex does) then being able to compare rear toe between ARS and non-ARS setups is useful. So that's probably why some '15 setups are showing odd toe values.
Team Xray
Old 03-19-2015, 07:25 AM   #1106
Satish's Avatar
Default Shock Length
Hey All,
With these shorter shock lengths on the T4 what is a good length from tip to tip?
s
Satish is offline   Reply With Quote
Old 03-19-2015, 07:59 AM   #1107
Salkin's Avatar
Originally Posted by Satish View Post
Hey All,
s
Maybe it is just me, sorry, but I do not understand your question
Old 03-19-2015, 09:28 AM   #1108
vabroom's Avatar
I think he wants the overall length of the shock.
Old 03-19-2015, 09:34 AM   #1109
Satish's Avatar
On the T4 there are 4 shocks, 2 on the front 2 on the back.
They made these shocks shorter then past TC's so I was wondering what an ideal length would be, from end to end.
For the original shocks they were around 63mm
So just need a ball park for the short shocks
s
Old 03-19-2015, 10:15 AM   #1110
daleburr's Avatar
s
I measure between the bottom of the shock body and top of shock balljoint, which I set to 9.5mm. Usually you have about one thread showing above the balljoint.
Team Xray
