Like Tree1Likes
Old 03-15-2015, 08:41 PM   #1081
Hey guys, I am switching to xray here at in the near future and just wanted to know the difference between the ecs from hudy and spec R? Is it just $50 or is it worth spending the extra cash to get the ones from xray. Besides the normal spares any part suggestions for med/low grip asphalt? Thanks in advance.
WEEZY is offline   Reply With Quote
Old 03-16-2015, 01:19 AM   #1082
Salkin's Avatar
If you buy the Hudy ECS's be sure to get the latest version on them. They are called "extra hard" and have the part no. 305332.
They are much more durable than the two earlier versions. We run mod and they hold up fine. We have used the earlier versions also and they broke, so I can say that the new extra hard ones work.
We have broken an Arrowmax ECS as well, so we went back to the Hudy extra hard ones and still uses them.
The Hudy ECS's are more expensive than the other brands, yes I know, but if you are maintaining them or even run a stock class, they will last for a long time.
I think many went for other options than the original Hudy ECS's because of the early durability issues, and the Hudy ECS may got a deserved bad reputation, but with the new extra hard versions, I think that reputation is no longer justified.
I have had a minor issue with the Arrowmax ECS's that didn't fit perfectly into the spool cups because of a misaligned pin.
Whether the Hudy ECS's are worth the extra cash, probably not 1:1, but I use them because I want to be sure to buy a spare part that is 100% guaranteed to fit.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 03-16-2015, 12:36 PM   #1083
Originally Posted by Govert View Post
Local distributor send me new plastics, issue solved! Great service. A+
Hi, Govert.
Have you been switch to Xray or is this rumor.
Ed
eded1 is offline   Reply With Quote
Old 03-16-2015, 02:27 PM   #1084
Official switch
Got my Xray a month ago already, but was still waiting for a brand new LRP speedo. Got it today.
Looking forward to hurt some asphalt on the MACH track...
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 03-16-2015, 03:19 PM   #1085
where do you buy the t4'15? or do you Know who is selling one
achtung6 is offline   Reply With Quote
Old 03-16-2015, 03:49 PM   #1086
vabroom's Avatar
This might be the only one left until the shipping docks caught up!
http://www.superiorhobbies.com/store...ouring+Car+Kit
Upon further review:
http://www.discountrcstore.com/XRAY_...5_p/300021.htm
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 03-17-2015, 04:04 AM   #1087
R Dodge's Avatar
Great! Glad to hear it worked out!
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is online now   Reply With Quote
Old 03-17-2015, 02:58 PM   #1088
reg
Official switch
Got my Xray a month ago already, but was still waiting for a brand new LRP speedo....
Do you mean new to you or have they brought out a new one?
reg is offline   Reply With Quote
Old 03-17-2015, 03:10 PM   #1089
Official switch
I try to assist to be cruel to the tormack
Sad to hear something called LRP and they let you waiting brrrrrrrrrr.
See you over a few weeks
Ed
Old 03-17-2015, 03:49 PM   #1090
Sorry to confuse you. For me a brand new one. LRP will not release a new speedo soon.
Ed
DEAL!
Btw, a few weeks??? Let's make it a few days
Modified 4 life
Old 03-18-2015, 03:53 AM   #1091
Salkin's Avatar
I use the Hudy ECS's and the standard plastic spool cups get worn quite quickly (running mod).
Is there a steel spool cup replacement to be used instead? Ones that does not require to use blades.
The manual mentions the part no. 305137, but those steel axel driveshafts requires the use of blades.
Old 03-18-2015, 04:10 AM   #1092
Geberit's Avatar
Did you see this?
http://www.minizracing.it/minizshop/...oducts_id=6164
http://www.minizracing.it/minizshop/...oducts_id=6070
Geberit is offline   Reply With Quote
Old 03-18-2015, 04:17 AM   #1093
Salkin's Avatar
Thanks for the links.
I have found some from Roche and Radtech also.
Guess Xray only makes ones that requires blades.
Old 03-18-2015, 12:57 PM   #1094
DEAL!
Let us hope for good conditions soon?
Old 03-18-2015, 01:01 PM   #1095
Try Arena out drives, very good steel no blades, cups have 4 sleeves.
Dont forget to put some grease f.e. tamiya heavy duty grease.
I use them for mod 4.5 on a very demanding track and they do well.
