Like Tree1Likes
Old 03-04-2015, 01:46 PM   #1066
Yes, that could be very much the case. I'm not jumping conclusions yet, but I can exclude any errors from my side. I already emailed Xray (not directly to mr Hudy) and I hope they have something useful to say.
I'm not disappointed, things like this happen from time to time. I know how well your Xray is performing, that's one of the reasons I bought one
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 03-04-2015, 01:48 PM   #1067
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Couple questions for you guys:
Anyone use the aluminum screw kit?
How much weight does it save over stock screws?
Are there any high stress areas where aluminum screws aren't recommended?
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 03-04-2015, 03:02 PM   #1068
R Dodge's Avatar
Originally Posted by Govert View Post
Thanks a lot for your help. I will let you know if new plastics are the solution.
Looking forward to hearing the result. Hope it fixes everything!
I use the Hiro Seiko aluminum/titanium screw set that EA sells. This kit is really good because it basically gives you all aluminum screws for the top side of the car and all titanium for the bottom. I wouldn't thread aluminum into the bulkheads from the bottom, but I've never had an issue with alum up top.
As for weight savings, I can't say exactly but I know I needed 2g this past weekend and in order to achieve it I replaced 8 ti screws on the bottom with the kit steel screws.
Hope this helps
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is online now   Reply With Quote
Old 03-04-2015, 03:34 PM   #1069
Trader Rating: 23 (100%+)
I have a hiro seiko alum/ti screw set. No problems with TI screws but in my opinion its too easy to accidentally destroy the alum screw heads. I have replaced all the alu screws with stock steel screws as i have damaged a few alum screws and its far too much trouble to remove when the head is destroyed. Weight saving for the entire set of screws is about 20g i think
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 03-05-2015, 12:48 AM   #1070
daleburr's Avatar
I'd go with the Hiro Seiko full Ti kit instead. Only a few grammes heavier and no chance of them stripping or breaking. Weight saving is ~18g I think.
Team Xray
Old 03-05-2015, 05:56 AM   #1071
Lonestar's Avatar
Trader Rating: 13 (100%+)
Originally Posted by eded1 View Post
OK, this is something that is missed by quality control.
If you write this including the film to M Hudy he will take action because they
are very proud persons and they know it harms Xray's reputation.
Ed
it took Xray a while to admit the blunder on the xb4 rear block
(but indeed they fixed it after a while...)
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-05-2015, 06:16 PM   #1072
J-milz's Avatar
Trader Rating: 37 (100%+)
Aren't the bulks different on the '14?
http://www.rcsupermarket.com/PDT/Xra...2015_5327.html
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 03-06-2015, 03:30 AM   #1073
Essnowyt's Avatar
Send a message via AIM to Essnowyt
I would check the viability of that item/seller. I do not believe Xray offered a conversion kit. I could be wrong, but conversion kits not been offered for some time.
The 2015 car has different chassis, motor mount, bulk heads, upper clamps, servo mount and sway bars.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 03-06-2015, 05:33 AM   #1074
RC MARKET's Avatar
Trader Rating: 12 (100%+)
XRAY had new option parts for T4'15
Old 03-06-2015, 05:41 AM   #1075
Salkin's Avatar
I already use those (mod), they are strengthened where I broke the "not strengthened", so they seem OK.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 03-06-2015, 10:11 AM   #1076
oladele's Avatar
Hey everyone, I just got a text from a racer that had raced with us a few times and wanted to share it with everyone because you guys are the reason behind it and I owe each and every one you a huge debt of thanks for it.
"Man this group is the best in terms of fun and quality, by far in USA. Thank you for awesome management I've ever seen. "
oladele is offline   Reply With Quote
Old 03-14-2015, 06:28 PM   #1077
SpidarX's Avatar
What brand spur gear does everyone recommend for the T4 '15?
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 03-14-2015, 07:52 PM   #1078
locked's Avatar
64P I like Titan, Core RC, ARC or Leespeed
48P I just use the kit XRAY spurs. I like to run 48P in mod.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 03-15-2015, 01:58 PM   #1079
Panaracer.
Modified 4 life
Old 03-15-2015, 02:01 PM   #1080
Local distributor send me new plastics, issue solved! Great service. A+
Modified 4 life
