Like Tree1Likes
Old 03-02-2015, 07:27 PM   #1036
alecladanga's Avatar
TITC 2015 A Main Modified Class Finals 1 & 2
Cant locate finals 3
https://www.youtube.com/watch?v=b0bTI0D6GC0
https://www.youtube.com/watch?v=TO9KTCHC2_k
Old 03-02-2015, 11:20 PM   #1037
Originally Posted by Boostinswifty38 View Post
I personally go back and forth with a front gear diff. Currently, it's on the car. 2.5mil cst in it. I dont ever recommend putty or ear plugs, as they break down over time and makes the diff really really inconsistent.
I use the diff when I want more corner entry steering, and less on power steering. It also seems to suit my driving style better, as I usually go in really deep into a corner, and expect the car to rotate on command. Others with a more "Refined" and "smoother" driving style might not benefit from this as much. I personally like it. I used it yesterday, and from the qual to main only switched the rear diff fluid and went up to 3k from 800, and lengthened all the camber links. car rotated well, had plenty of steering and was stable. very consistant. I also run a different spring package then anyone at my track atleast, but I have it working quite well for me. I also ran some new, other parts for the car, but that isn't on point here.
I would use the diff as a tuning tool like anything else. I can see it benefiting what I outlined above, especially on more technical tracks or ones with tight turns when you want more entry steering.
Great thanks for the info
hershey66 is offline   Reply With Quote
Old 03-03-2015, 07:11 AM   #1038
RedBullFiXX's Avatar
R/C Tech Elite Subscriber
Trader Rating: 34 (100%+)
A3 Mod
+ YouTube Video
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
RedBullFiXX is offline   Reply With Quote
Old 03-03-2015, 03:20 PM   #1039
Trader Rating: 23 (100%+)
Originally Posted by niznai View Post
People have commented about this in other threads. I think (from personal experience) right now the Tamiya ECS shafts are the strongest on the market (Yokomo are pretty much on par with Xray). They have the same axle length and there are a few options for dogbone length (you can buy bits separately and mix and match).
The problem is the fit in the outdrive. Xray's outdrives are 1mm larger than the Tamiya dogbone end.
One way to get around this is to use a T1 spool (which is 5mm inside the outdrive and fits the Tamiya dogbone directly) or insert a brass collar in the current Aluminium Xray outdrive and cut the driving slots in it.
Another way to fit TRF DCJ's into a T4 is to use smokem spool cups: http://shop.smokem-racing.com/Smokem...DCJs_p_20.html
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 03-03-2015, 06:02 PM   #1040
rcfiend's Avatar
Trader Rating: 29 (100%+)
Guys I'm having an issue with getting my lower shock ends to move freely. I have bought new ones and installed them on the non shiny side and they still do not move freely. Any suggestions.
rcfiend is offline   Reply With Quote
Old 03-03-2015, 06:24 PM   #1041
Trader Rating: 21 (100%+)
You may have the shock shaft threaded into the end too far. Try unthreading a full turn or two and see if that frees it up.
Sir Loin is offline   Reply With Quote
Old 03-03-2015, 07:23 PM   #1042
rcfiend's Avatar
Ahh. I'll give that a try.
Old 03-03-2015, 07:28 PM   #1043
rcfiend's Avatar
Sir Loin that was it. Thanks. I'm so use to threaded the shocks until the threads just start to disappear.
Old 03-04-2015, 01:41 AM   #1044
Skiddins's Avatar
For a decent length you should still around 1mm of thread showing at the end and have around 9.2mm from the bottom of the shock body to the top of the end ball joint.
So the total amount of ths shock rod showing should be 9.2-9.5mm
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 03-04-2015, 03:22 AM   #1045
Guys,
I have a question about my shock ball joints and my pivot balls on my T4 2015. I have read the manual very very closely and still I don't get it. I also have been asking this on rctech before, but pics and videos might clear things up.
The situation how I have my shocks installed is:
Top part of the shock, shiny part pointed TOWARDS the pivot ball.
Bottom part of the shock, shiny part pointed AWAY from the pivot ball.
Now this; I try to move my ball joints freely over the pivot balls, but on the top part of the shock, the ball joint does not move freely. I mean by that, it some sort of "sits" at the base of the pivot ball. When I try to wiggle it, it has a restricted movement. But when I pull it out a little bit, the ball joint moves freely. It looks like it "clicks" into place when I don't pull the shock out.
https://www.youtube.com/watch?v=scnQfYRk_ho (The worn tires are just there for other reasons...)
Is this normal what you see on the video?
If not, could anyone tell me what's wrong here?
Thanks in advance.
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 03-04-2015, 04:18 AM   #1046
R Dodge's Avatar
Hi Govert,
Looking at the picture, it appears you have the pivot ball in the top eyelet backwards. If you look closely at the opening where the pivot ball goes, you can see a ring around it. That ring is supposed to face the side of the pivot ball that has the flat on it. Yours currently faces outward/the side of the pivot ball that the hex is on.
You can easily identify this by the vent hole on the top eyelet. It's kinda hard to tell in the pic but I think I can see it. That should be facing the shock tower.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 03-04-2015, 04:46 AM   #1047
Thank you for your answer Dodge.
Well, the vent holes are pointed towards the shock tower(s). I can understand the confusion, because it seems like there's this shiny ring on the outside of the top eyelet. It actually is a mark of a shim/spacer I used to pop the pivot in the eyelet (like the manual is pointing out). The bottom eyelet has the shiny side pointed outward, as you can see.
So the shiny side of the eyelet is pointing towards shock tower, as wel as the vent hole...
Modified 4 life
Old 03-04-2015, 04:53 AM   #1048
R Dodge's Avatar
Well, the vent holes are pointed towards the shock tower(s). I can understand the confusion, because it seems like there's this shiny ring on the outside. It actually is a mark of a shim I used to pop the pivot in the eyelet (like the manual is pointing out).
Interesting. Makes sense about the marking from the shim. That is unusual though. Is this a new kit? Play is normal but clicking into place is not. It should have free movement on the pivot ball. Are all 4 shocks doing this?
Edit: Just got a chance to watch the vid but I don't have sound. The movement looks fine when you pull it out, as you say. It's hard to tell what is going on with that clicking into place that you mention. Mine move pretty freely no matter where they sit on the pivot ball; whether it be back against the flat, or up on the front of the ball. I always polish all my pivot balls though. I'm not sure if this might be part of the reason yours don't feel smooth to you, but it is worth doing regardless. I'm honestly kinda stumped otherwise. Only other explanation in my mind would be a bad shock top but it's hard to imagine there would be 4 bad ones in a new kit.
Old 03-04-2015, 04:58 AM   #1049
Yes, all four are doing this. And yes, this is a new 2015 kit. Very strange to me as well.
I'm not a novice builder, so I can exclude any stupidity from my side in regards to overtightening/forcing/deforming any parts. So this is strange indeed.
Modified 4 life
Old 03-04-2015, 05:02 AM   #1050
R Dodge's Avatar
Yea, it would be really hard to mess up the plastic there. I edited/added more to my previous post after getting to actually see the vid. I'm not sure if that might help you at all. Just want to make sure you see it.
