Like Tree1Likes
Old 02-21-2015, 11:06 PM   #1006
rcfiend's Avatar
Trader Rating: 29 (100%+)
Originally Posted by artwork View Post
52s are the most common in the front. ECS improves Corning and makes the cars arch through the corner much smoother.
Thanks Artwork!
rcfiend is offline   Reply With Quote
Old 02-23-2015, 04:51 AM   #1007
nerdling's Avatar
Originally Posted by Slippery Dan View Post
Thanks!
What about foam tires? Are those just not used as much now?
Speaking as one of those non existent foam racers () we tend to run Matrix, VMR or Caprcorn 26mm tires. Normally with a harder front tire. 40 shore at the front and 37 on the rear, or 37 front and 35 rear. In some cases, 37 shore in a front compound with a 37 rear (but this setting is pretty aggressive).
I'd grab a pair of 40's and 37's, then find out what the guys at the track are running...
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 02-23-2015, 05:16 AM   #1008
Salkin's Avatar
How does it affect the car to run ECS in the rear?
Can see some team drivers use this option.
Is it a real benefit, only in some circumstances, or just "bling-bling"?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 02-23-2015, 08:06 AM   #1009
R Dodge's Avatar
The reason I've been told is to get more steering/rotation from freeing up the rear. I tried it once about 2 or 3 years ago and didn't really feel a difference. Though, I will admit that I could have done a more accurate test than I did.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 02-23-2015, 08:13 AM   #1010
Trader Rating: 14 (100%+)
Thanks. There are a couple guys talking of running an "anything goes" class so they might end up running foam anyway.
Slippery Dan is offline   Reply With Quote
Old 02-23-2015, 10:49 AM   #1011
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
How do you guys feel about aluminum spool drive cups? I broke a plastic one this weekend, and was looking around for replacements. Would aluminum put more stress on the Ecs shafts? I'm running the 50mm X-ray ecs and have never had a problem with them. Should also note I run the spool with foam tires on carpet. Thanks in advance!
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 02-23-2015, 11:13 AM   #1012
locked's Avatar
Metal spool outdrives do tend to put more stress on the drive shafts. I've used Nikita aluminum outdrives many times in the past(they require 50mm shafts. will bind with 52mm). I currently have xray spring steel outdrives in all of my cars. I use ECSes in my 17.5 car and USGT car and I haven't broken any ECS on those cars in over a year, but I had to go back to the kit shafts in my mod car after completely shearing off several of them just from braking at the end of the straight. 3 different kinds of ECS all failed the exact same way. Sheared off just from hitting the brakes at the end of the straight. All broke at the barrel end of the shaft. Current layout at the local track would probably be a bit easier on the car. Last layout was brutal for the forces it put on the cars. I'm not the only one who kept killing shafts under braking. Several friends had similar issues.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 02-26-2015, 01:19 PM   #1013
Default Alu Front steering block
I am looking for a set of Alu steering blocks for my T14. I cant find any in UK model shops or even Ebay. Can anyone tell me where to get some from. they do not have to be original xray.
Cheers
Kevin
kevinkirk is offline   Reply With Quote
Old 02-26-2015, 11:45 PM   #1014
Geberit's Avatar
Hagberg fastest at TITC 2015 Q1! No ARS on board?
Xray t4'15-10408075_1021029487925929_1587507494825941014_n.jpg   Xray t4'15-11026250_1021071864588358_5036540008997951102_n.jpg
Geberit is offline   Reply With Quote
Old 02-27-2015, 12:48 AM   #1015
I don't know about aluminum, but I use the Roche Spring Steel ones, and they've been great.
-Mike
Old 02-27-2015, 07:07 AM   #1016
Trader Rating: 20 (100%+)
Has anyone tried using the Spec-R once piece center motor mount?
Thoughts?
http://www.spec-r.com/default/index....roducts_id=763
bee200sx is offline   Reply With Quote
Old 02-27-2015, 07:13 AM   #1017
Geberit's Avatar
Thoughts?
Some one earlier was selling it because it strips gear.
Old 02-27-2015, 07:47 AM   #1018
niznai's Avatar
People have commented about this in other threads. I think (from personal experience) right now the Tamiya ECS shafts are the strongest on the market (Yokomo are pretty much on par with Xray). They have the same axle length and there are a few options for dogbone length (you can buy bits separately and mix and match).
The problem is the fit in the outdrive. Xray's outdrives are 1mm larger than the Tamiya dogbone end.
One way to get around this is to use a T1 spool (which is 5mm inside the outdrive and fits the Tamiya dogbone directly) or insert a brass collar in the current Aluminium Xray outdrive and cut the driving slots in it.
Cheers
Kevin
Hobbyking HK has originals but of the pair they sent me did not have the thread cut for one of the kingpin ballstuds.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 02-27-2015, 03:57 PM   #1019
Hi
How good is this car stock out of the box on the track?
Is it easy to tune it for your track or does it take awhile to get it to work right?
Looks amazing ,just wonder if it is really worth the money?
My second choice is the durango detc410
hershey66 is offline   Reply With Quote
Old 02-27-2015, 05:53 PM   #1020
B00t13g's Avatar
R/C Tech Elite Subscriber
Originally Posted by hershey66 View Post
Hi
Out of the box the t4 15 is competitive, the base setup is a great starting point and you will have more than enough support from other xray drivers.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
