Like Tree1Likes
Old 02-14-2015, 03:20 AM   #991
Stupid question; Just building my T4 and noticed the manual does not show how to mount the composite ball joints. They have a shiny side and a normal side. Should the shiny side point to the ball end side or the other way around? I just want to be 100% sure, because I know this detail is important.
And I saw something strange when building the shocks; top end cap the shiny parts points towards the ball end. But the ball joints on the bottom of the shock should be installed with the shiny side the other way around. That seems strange to me. Is this right?
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 02-14-2015, 03:49 AM   #992
...double post
Modified 4 life
Old 02-14-2015, 05:37 AM   #993
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Both are correct. The ball joints for the links are interchangeable for their direction, shinny vs. dull. However the shock parts you should follow the manual.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 02-14-2015, 05:51 AM   #994
Thank you Snowy. For the sake of clean looks I will install the ball joints for the links with the shiny side towards the ball end.
Thanks again for clearifying.
Modified 4 life
Old 02-17-2015, 06:36 PM   #995
Trader Rating: 14 (100%+)
I've been out of carpet (and onroad) racing for quite a while.
I just picked up my new Xray and I have been looking through setup sheets for tires that I need.
Most of the setups though don't specify anything other than tire brand.
What tires, both rubber and foam, are being used these days?
Thanks.
Slippery Dan is offline   Reply With Quote
Old 02-17-2015, 09:19 PM   #996
Danny-b23's Avatar
Thanks.
Best choice is usually what the other guys in your club run.
If it isn't one tire across most people, Sorex 28s on carpet are pretty hard to beat.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-18-2015, 12:36 AM   #997
Salkin's Avatar
Ride makes some good sets also.
We also use Sorex 28 indoor mostly, but have tried both LRP and Ride tires and have found that the Sorex pre glued tires more easily breaks the rims than the LRP and Ride pre glued sets I have tried.
Less of an issue if you do not run on a narrow track with hard sides/curbs.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 02-18-2015, 09:00 AM   #998
Thanks!
What about foam tires? Are those just not used as much now?
Old 02-18-2015, 09:16 AM   #999
locked's Avatar
Thanks!
You might find an obscure club or two that still run a foam tire sedan class, but they are virtually extinct, everywhere.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 02-18-2015, 09:16 AM   #1000
Trader Rating: 28 (100%+)
Thanks!
nobody races foam sedan anymore.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 02-18-2015, 09:30 AM   #1001
patorz31's Avatar
I am ordering a bunch of stuff to build my ultimate tire. Sorex 28's unmounted, The Sweep Nylon Rim that seems indestructible and an now just trying to find the JB black inserts. I f I can't find any I will just cut them out of some old tires.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is offline   Reply With Quote
Old 02-18-2015, 10:16 AM   #1002
locked's Avatar
I love that combo! JB are the blue inserts though. The Sweep lightweight blue inserts (EXP-LS) look to be identical to the Schumacher inserts they use in JB sets. They work great.
So far I haven't found the identical insert to the Schumacher RK (black) ones. I have cut some out of old Schumacher sets to reuse. The sweep black inserts weigh a lot more.
Dave Locke
Old 02-18-2015, 12:06 PM   #1003
Fine with me!
I think I still have some of that stuff in my lungs from 10 years ago!
Old 02-21-2015, 09:08 PM   #1004
rcfiend's Avatar
Trader Rating: 29 (100%+)
Just finished my build, which ECS does everyone run, 50 or 52? What is the benefit vs stock cvd's?
rcfiend is offline   Reply With Quote
Old 02-21-2015, 09:35 PM   #1005
artwork's Avatar
Trader Rating: 62 (100%+)
52s are the most common in the front. ECS improves Corning and makes the cars arch through the corner much smoother.
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
