Like Tree1Likes
Old 01-26-2015, 02:51 PM   #946
chasingthepack's Avatar
http://forum.teamxray.com/xform/inde...&setup=t4_2015
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-26-2015, 10:55 PM   #947
Default T4-15
Originally Posted by Skiddins View Post
No you haven't
see the link in the above post
andrewd is offline   Reply With Quote
Old 01-27-2015, 04:08 AM   #948
Salkin's Avatar
In Martin Hudy's LRP start setup, the eccentric bushings in the rear seems to add to the standard toe of 3 degree, but still the setup sheet states 3 degree for final toe in.
Can someone please explain that to me.
Martin's setup:
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 01-27-2015, 08:13 AM   #949
rcfiend's Avatar
Trader Rating: 29 (100%+)
I just picked up a T4 15. Was in the process of ordering spur gears and there appears to be several between the various Xray sedans. Is the part number I need for a 64 pitch 96 spur - XRA305866
http://www.amain.com/xray-64p-offset...ar-96t/p173469
rcfiend is offline   Reply With Quote
Old 01-27-2015, 08:21 AM   #950
Trader Rating: 308 (100%+)
Can you use the stock chassis on the T4 14, would like to play around with the ARS.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 01-27-2015, 08:41 AM   #951
rcfiend's Avatar
Disregard, I just checked the manual and its the correct spur gear. I've been out of On-Road for awhile. What's the preferred body for carpet racing?
Old 01-27-2015, 08:52 AM   #952
locked's Avatar
PF Mazdaspeed6 is the most popular choice for carpet. The New PF Dodge Dart looks to be a good shell for carpet as well.
Although those offset spurs can work, I've never liked using them. I prefer CoreRC, Titan or Leespeed for 64P spur gears.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 01-27-2015, 09:07 AM   #953
rcfiend's Avatar
Thanks for the information Locked. I'll take a look at the other spur gears as well.
Old 01-27-2015, 12:49 PM   #954
Salkin's Avatar
Martin's setup:
New corrected setup sheet posted.
Old 01-27-2015, 02:22 PM   #955
Skiddins's Avatar
Martin's setup:
Kit pivot blocks creatr 3deg of rear toe, sheet is correct
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-27-2015, 02:24 PM   #956
Skiddins's Avatar
Not without some changes, servo mount for example, is different holes in chassis as well as different screws and holes for motor mount etc.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 01-27-2015, 06:31 PM   #957
I have added the 2 holes for the ARS system to my '14 aluminum chassis. You can see them in the attached pic. The motor mount and servo mount holes are different in the '15 chassis.
team_tamale is offline   Reply With Quote
Old 02-01-2015, 01:34 AM   #958
LKF
thats right. i would do the same - drill two new holes in 2014 chassis plate.
its easier and cheaper.
LKF is offline   Reply With Quote
Old 02-02-2015, 03:33 AM   #959
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Xray won the amateur tc class, stock tc, super stock tc, mod tc and 12th scale mod. It also tq'd vta and had the fastest laps in the main but young Jarrett parsons just had no luck. The entire Xray team worked awesome together to come up with some really fast and easy to drive setups for everyone. They should be listed up on the site soon!
EA
EAMotorsports is offline   Reply With Quote
Old 02-03-2015, 06:07 AM   #960
oladele's Avatar
EA
Great job EA and Team Xray
oladele is offline   Reply With Quote
