Like Tree1Likes
Old 01-15-2015, 12:11 AM   #901
Geberit's Avatar
Many times drivers use anti-dive on front arms. How or where do they measure down-stop in this situation?
Geberit is offline   Reply With Quote
Old 01-15-2015, 12:55 AM   #902
niznai's Avatar
This is one of the reasons I always measure it at the wheel axle.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 01-15-2015, 01:04 AM   #903
Salkin's Avatar
My son drives modified with a T4'15. He is OK, but does not drive flawlessly like the "pros".
We like to try the alu chassis, as many seems to try them.
At the recent DHI Cup, most of the top drivers either tested the alu chassis or used one.
My question: how much beating can such an alu chassis take before it bends and becomes useless?
Or is alu chassis just the latest "new thing", forgotten tomorrow?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 01-15-2015, 02:18 AM   #904
daleburr's Avatar
Originally Posted by Boostinswifty38 View Post
Anyone else running roche racing driveshafts? For the second race now, while leading tonight, it was lost because a small tap, not enough to do damage or even dirty the body, and the nut and axle and snapped off, sending the wheel flying and ending my race prematurely. What's with the crap material used in these?! And where can I get Spare parts for the Roche axles?
I ran mine for 12 months and they still look like new, so they've just gone into my new '15 build. Had some big crashes and no damage.
Maybe they've changed the materials. How long have you had them? Are they the latest ones with the holes drilled in the cage?
Team Xray
daleburr is online now   Reply With Quote
Old 01-15-2015, 03:35 AM   #905
Geberit's Avatar
If you take the standard setting F6/R5 how much would that be under the wheel axle?
Old 01-15-2015, 07:01 AM   #906
I'm unsure what ya mean holes drilled in the cage? For the round clips to hold the pin in?
These axles are not even 4 months old.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 01-15-2015, 10:14 AM   #907
Odin544's Avatar
Trader Rating: 93 (100%+)
I cant speak for the Xray aluminum chassis, as I've been using the Team Tamale chassis on my T4'15. They are much more durable than you would think. I was concerned about it as well. Not so much anymore.
TriCitiesRC.com
Old 01-15-2015, 10:20 AM   #908
Odin544's Avatar
Been using them with no issues at all. Every crash is different. Not damaging the body means absolutely nothing. All it takes is for an axle to get caught on the barrier in some way and its done.
Could easily have been another much harder crash that broke it, and it was just holding together. The little tap finished it off. I've had this happen a lot in off-road. Downside a jump perfectly, and an arm breaks. Wasn't the landing that broke it, it was something earlier. It just happened to give up at that moment.
TriCitiesRC.com
Old 01-15-2015, 10:56 AM   #909
Salkin's Avatar
Thanks, I'm now a little closer at getting one
Old 01-15-2015, 04:10 PM   #910
niznai's Avatar
That's the trouble you land in when trying to copy setups. I am using a square to measure and that is my reference, I don't use a downstop gauge. You'll need to work out your own reference.
Team Greasy Weasel
Old 01-15-2015, 04:26 PM   #911
niznai's Avatar
double post
Team Greasy Weasel
Old 01-15-2015, 06:01 PM   #912
rangerjkb's Avatar
Trader Rating: 40 (100%+)
Send a message via MSN to rangerjkb
I've been using Roche DCJ's for about 14 months and have only broken one axle shaft, specifically the ball end on the axle shaft. So far they have been fantastic. I haven't found a "Go to" store in the U.S. that stocks them so I had to order directly from Roche.
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 01-17-2015, 01:34 PM   #913
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Looks like Spec-R has a new motor mount/layshaft/ARS mount for the '15. Might be a nice option for lower grip or more even chassis flex.
http://www.spec-r.com/default/index....roducts_id=739
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 01-18-2015, 05:08 AM   #914
[QUOTE=Kevin K;13788292]Looks like Spec-R has a new motor mount/layshaft/ARS mount for the '15. Might be a nice option for lower grip or more even chassis flex.
srp67 is offline   Reply With Quote
Old 01-18-2015, 08:16 AM   #915
SpidarX's Avatar
Originally Posted by pphaneuf View Post
The manual emphasizes in two separate diagrams that the narrow side of the offset spur gear should go on the side with the spacer, which should go on the side of the short belt (motor side). See this album, for the diagrams in question, and photos of how I've built it:
https://plus.google.com/photos/+Pier...37555285064881
But check out how freakishly close that comes to the top deck (and how much of the motor shaft):
I'm pretty sure I should relax, I'm just not sure if I should relax about a) how close this comes to the top deck, or b) following the manual closely.
I have the same problem using the xray offset spur. Using the standard spur, everything lines up perfectly.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
