Like Tree1Likes
Old 07-15-2014, 10:10 PM   #76
niznai's Avatar
I have a long record of practice in this kind of testing, and only ever managed to break a tie rod end and that was the kit Tamiya aluminium one form the TA05R. That is when I discovered how soft the material was.
Bent a lot of hinge pins on the same car, front and rear. Which again testifies where Tamiya considered appropriate to set the failure point. Problem is, it fails too easily even when using their Titanium coated shafts. I replaced the hinge pins on the car with tool steel pins I made at home and no breakage since.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 07-16-2014, 07:09 AM   #77
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by grippgoat View Post
Actually, Awesomatix started the current aluminum chassis trend.
-Mike
Actually X-ray had it on carpet with foam tires before awesomatix was ever a thought. But recently shaftie has brought the idea back to the top.
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-16-2014, 07:24 AM   #78
theproffesor's Avatar
Trader Rating: 55 (100%+)
Didn't Associated use a gold one back in the late 80's????
What was once used because it was too expensive for anything else to be used, went by the wayside with new materials and manufacturing processes. Now aluminum is hot again b/c it offers different characteristics and can be made stronger and cheaper than in years past.
For those of us that have been in this hobby since the 80's, it is relatively less expensive now than it was then. Even with $500+ kits. Kits are about the same dollar amount, motors about the same, batts way cheaper, electronics the same or cheaper. All with durabilty and longetivity of parts going way up. So given inflation and generally better incomes than 25 years ago...
But I still agree that it does seem shady to offer race level kits that need an additional $150 or more to run what is considered "standard" by most racers and the factory driver. X-ray isnt the only company that does this (TLR, Tamiya, Kyosho)
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 07-16-2014, 07:44 AM   #79
TRF418 has all the hardware needed in the box (Including DCJ’s). Any other hop ups are just bling.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 07-16-2014, 11:03 AM   #80
Geberit's Avatar
Included Graphite suspension arms!
Geberit is offline   Reply With Quote
Old 07-16-2014, 06:41 PM   #81
That's why I said "the current aluminum chassis trend". I've only been into RC since late 2009, which is not long enough to have seen an old trend of aluminum chassis in TCs, but long enough to know that there probably was one.
-Mike
Old 07-17-2014, 01:47 AM   #82
Skiddins's Avatar
Too twitchy on some carpet tracks.
They're fine if you have high grip
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 07-17-2014, 07:17 AM   #83
Geberit's Avatar
The Team drivers use them all the time. Doesn't matter what kind of surface or gripp.
Example Hagberl low grip asphalt: http://www.petitrc.com/reglages/xray...as20140629.pdf
Example Martini low grip carpet: http://www.petitrc.com/reglages/xray...ze20121203.pdf
Look at the different team set-up's .... ''99%'' independent of the gripp an surface graphite arms are used.
Old 07-17-2014, 08:48 AM   #84
Skiddins's Avatar
I know they do.
But to the average joe like me, I've gone quicker and had an eaiser to drive car with standard wishbones (or when I've removed the carbon plates)
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 07-17-2014, 08:52 AM   #85
Chaz955i's Avatar
I know they do.
Apparently you never got the memo that says if a team driver does something you should do the exact same thing without question because if it works for them it must work for you.
Chaz955i is offline   Reply With Quote
Old 07-17-2014, 12:57 PM   #86
Geberit's Avatar
This sentence may sound smart but I saw people with 10+ years of experience trying on their own and faild to set-up a car properly. Then they went to Martin H. and copied the set-up (complete car) and look suddenly the results were much better and smile on their face was back. I visited many ETS races and a lot of the regular guys go to the team drivers to get some good info including me
Old 07-17-2014, 01:12 PM   #87
jlfx car audio's Avatar
Trader Rating: 35 (100%+)
This is true but dont always believe whats posted online vs what they (the pros) tell you to do at the track... sometimes numbers get ...... fuzzy the day or week after a big race ;-)
jlfx car audio is offline   Reply With Quote
Old 07-17-2014, 02:29 PM   #88
chasingthepack's Avatar
+1
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 07-17-2014, 11:41 PM   #89
Geberit's Avatar
Yes you ar absolutely right. It could be marketing so we all spend our money on graphite arms i'm aware of that.
Old 07-18-2014, 05:20 PM   #90
hanulec's Avatar
R/C Tech Elite Subscriber
Trader Rating: 27 (100%+)
i cannot believe i missed this thread. this is one of my favorites year over year..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
